marcello Schrauber
Joined: 01/22/2003 Posts: 26 Karma: +0 / -0 Location: südtirol
15-02-2003, 13:09 Subject: EDS System Error: Troubleshooting & Fixes |
The EDS (Electronic Differential Lock) in my friend's Seat Cordoba is engaging too early.
"That means that when you drive the car slowly around a curve, the hydraulic pump already turns on. I read the error memory."
"There was nothing there, so I then measured the individual wheel speeds under the measurement block, but they were all approximately the same."
(slight deviations are possible) of course, not when cornering! The car was manufactured in 1998 and has a Teves ABS-EDS system.
Has anyone else experienced problems like this?
Thank you for any help.
MARCELLO
Translated on 29-09-2026, 3:37.
Profile PM Email |
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
15-02-2003, 16:18 Subject: EDS System Error: Troubleshooting & Fixes |
Hello Marcello,
What type of TV is it (e.g., Mark30...)?
What speed was the car traveling at when it entered the curve?
Tschüss
Michael II
Translated on 29-09-2026, 3:38.
marcello Schrauber
18-02-2003, 12:41 Subject: EDS System Error: Troubleshooting & Fixes |
Okay, so it's an ITT Mark 20 ie ABS-EDS system with CAN-BUS.
As I originally intended, a Teves ABS.
and this phenomenon only occurs at very low speeds, up to approximately 5 km/h.
auf
Please urgently find a solution.
Thank you in advance.
MARCELLO
Translated on 29-09-2026, 3:39.
Profile PM Email |
Thomas K. Guest
18-02-2003, 12:55 Subject: EDS System Error: Troubleshooting & Fixes |
just a side note:
ITT, ATE, Teves, and Continental Teves are all from the same manufacturer, operating under the umbrella of Continental.
marcello Schrauber
18-02-2003, 13:00 Subject: EDS System Error: Troubleshooting & Fixes |
Okay, that's good! But please help me solve this problem.
Translated on 29-09-2026, 3:40.
Profile PM Email |
