A6 Avant V6 TDI: Broken Display for Navigation & MFA?
quattrotdi
Post17-02-2003, 12:12    Subject: A6 Avant V6 TDI: Broken Display for Navigation & MFA? Quote
a6 avant V6 TDI 4B - display for navigation and MFA (between the speedometer and tachometer).
Is the red text on the outer edges no longer readable?
The red turns black in the middle and at the bottom, while the rest remains normal.
Has anyone ever experienced this before?
Can this display be replaced individually, or do you need a new combined unit?
costs?
Thank you, Harald.
Translated on 13-10-2026, 2:21.
Michael II
Post17-02-2003, 12:22    Subject: A6 Avant V6 TDI: Broken Display for Navigation & MFA? Quote
Unfortunately, in the event of a fault, the entire instrument cluster must be replaced. The display is not available as a separate part.
Tschüss
Michael II
Translated on 13-10-2026, 2:22.
quattrotdi
Post17-02-2003, 12:29    Subject: A6 Avant V6 TDI: Broken Display for Navigation & MFA? Quote
hello michael,
Thank you for your help.
harald
No new posts 5F Leon, large navigation system with DVD, image display Electrical Systems, Vehicle Electronics, Multimedia
No new posts Is it possible to retroactively install a navigation syst... Transmission, Chassis, Body & Interior
No new posts Target values for the V6 TDI 150hp engine in an Audi Avan... Diesel Engine Technology
No new posts Audi A6 Avant V6 TDI: Running on 4 Cylinders? Diesel Engine Technology
