Cold start problems 1Z
blackblizzard
Post16-11-2009, 17:43    Subject: Cold start problems 1Z Quote
Hello!
The engine of a well-known car model is starting very hard. It takes approximately 20 seconds of cranking to start. It produces white smoke.
Spark plugs, starter, battery are okay.
No oil or coolant leakage.
Error memory is empty.
For one measurement block, the start of injection is within the specified range.
It starts immediately when warm, and otherwise has no problems.
What else could it be?
Best regards.
Post16-11-2009, 17:46    Subject: Cold start problems 1Z Quote
Use the search function! Enter "crankshaft bolt". The amount of results will overwhelm you. icon_wink.gif
No new posts A6 AAT cold start problems, the umpteenth... Diesel Engine Technology
No new posts AFN Cold Start Problems Diesel Engine Technology
No new posts T4 2.5 TDI ACV: Cold Start Problems Upload
No new posts Cold start problems with BLS 1.9 TDI engine Diesel Engine Technology
