Auxiliary Heater for VW T5
Schneemann
Avatar-Schneemann
Post24-11-2012, 11:23    Subject: Auxiliary Heater for VW T5 Quote
Hello everyone,
I'm planning to install an auxiliary heater (Webasto Top Thermo) in my T5 (manufactured in 2004, but first registered in 2005). The old one is broken, so I'm replacing it with a used one – hopefully it will work.
The control system for the glow plug is faulty on the Alte.
The new part has the number 7H0 819 008 H (the original part was 7H0 819 008 F). According to a well-known software, "H" is the replacement type for "F".
The installation itself is quite simple, but is there anything I need to change or adjust using VCDS? Is the control panel on the rearview mirror compatible with the newer device?
Sincerely,
or
With hopeful anticipation,
the snowman
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 29-09-2026, 9:59.
Schneemann
Avatar-Schneemann
Post02-12-2012, 10:18    Subject: Auxiliary Heater for VW T5 Quote
Thank you.
Gruß Schneemann
Translated on 29-09-2026, 10:00.
Karma: +807 / -0   Thank you, like it!
Post02-12-2012, 11:26    Subject: Auxiliary Heater for VW T5 Quote
If no one responds, it's likely that no one knows the answer.
The only sensible way is to use the VW parts catalog. I assumed that everyone would figure that out on their own, so I didn't mention it.
If the new part number is listed as a direct replacement for the old control unit in your vehicle, it will likely work.
Feedback regarding potential pitfalls or unexpected effects is, of course, welcome.
Schneemann
Avatar-Schneemann
Post02-12-2012, 12:30    Subject: Auxiliary Heater for VW T5 Quote
Hello Rainer,
It's fine if no one knows anything; that's just how it is.
I remember this from when I was in school. The teachers complained about my lack of participation. But why should I raise my hand if I don't even know a wrong answer?
Okay, I've never replaced a control unit with another one (a newer one) before. I'm not sure if there's a general risk of problems occurring in such replacements, especially if the software version is different. I would have preferred some general guidelines, but I probably should have asked directly.
But still: The replacement part was installed, it works perfectly right away, and I didn't even have to unlock anything. The T5 is getting warm again.
Happy Sunday.
Gruß Schneemann
Translated on 29-09-2026, 10:02.
Post02-12-2012, 12:57    Subject: Auxiliary Heater for VW T5 Quote
But still: The replacement was installed, it works perfectly right away, and I didn't even have to unlock it.
Great icon_smile.gif.
Translated on 29-09-2026, 10:03.
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Auxiliary Heater Control Unit Diesel Engine Technology
No new posts Auxiliary Heater Settings: How to Adjust On-Board Diagnostics (OBD)
No new posts Additional Heater for Sharan On-Board Diagnostics (OBD)
No new posts VW Sharan auxiliary heater malfunction Diesel Engine Technology
