Fuel Injector Replacement: Cost & Guide
atzleh
Post22-02-2003, 1:12    Subject: Fuel Injector Replacement: Cost & Guide Quote
Hello Audi fans! When, or at what mileage, should the injectors be replaced? My car sounds a bit 'rough,' and the current mileage is 250,500 km. I'm thinking about replacing them! Best regards, AFN driver.
Translated on 03-10-2026, 11:02.
Post22-02-2003, 7:38    Subject: Fuel Injector Replacement: Questions & Answers Quote
atzleh wrote:
Hello Audi fans! When, or at what mileage, should the injectors be replaced? My car sounds a bit "rough," and the current mileage is 250,500 km. I'm thinking about replacing them! Best regards, AFN driver
"There's no prescribed replacement interval for fuel injectors, but after 250,000 km, you should definitely consider replacing the original injectors. It's likely that the spray pattern of your injectors is no longer optimal, or that one or more injectors are dripping. A rough engine running is a sign of incorrect combustion, and the injectors play a significant role in that."
Personally, I believe that the nozzles should last approximately 150,000 - 180,000 kilometers.
Translated on 03-10-2026, 11:04.
