ZMSwing Check: Improve Your Golf Swing
roorback
Karma: +1 / -2   Thank you, like it!
Post30-11-2009, 11:36    Subject: ZMSwing Check: Improve Your Golf Swing Quote
Hello.
After a clutch replacement, which is now unavoidable and has been scheduled for 325,000 kilometers, I wanted to ask you experts for advice.
"As I mentioned, my car has 325,000 kilometers on the odometer, with almost 400 Nm of torque. Besides the well-known jerking/stuttering issues in fifth gear at around 1800 rpm (which I've had since I bought it as a used car 8 years ago), there are no other problems."
Okay, so I now have an engine for the basement, which I took out of a car with very low mileage and without any modifications.
A mechanic would visually inspect the flywheel for cracks, etc. - I assume nothing more is done.
My question is, are there any specific tasks related to the renovated swing set that I could entrust to a specialized workshop to restore the used swing set to the best possible condition? Could the surface be treated, or something similar?
Could a good workshop also test it and determine the condition?
Thank you for your help.
best regards, uwe
Translated on 24-09-2026, 9:13.
No new posts Inspect AHU Diesel Engine Technology
No new posts LWR Sensor Check: How to Test & Diagnose On-Board Diagnostics (OBD)
No new posts Check Catalytic Converter: Symptoms & How To Diesel Engine Technology
No new posts Chiptuning: Check with VAGCOM? Diesel Engine Technology
