Dual-Mass Flywheel: Benefits & Explained
Go to page: 1, 2, 3  Next
trebor
Post11-08-2008, 17:01    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
I'm having a problem with my clutch (engine code: ASV + gearbox code: EGS) that's making a rattling noise.
Now I'd like to know if a 240mm flywheel with clutch will fit on my car. Otherwise, I would switch to a 228mm flywheel.
I have 0.216 injectors and the engine is tuned, but I had to reduce the power at low RPM (up to 2000 RPM) because of excessive vibration.
If the 240mm clutch doesn't fit, and I were to switch to a 228mm clutch, would that be harmful to the transmission (input shaft + bearings), or could it handle it?
I know that the EMS isn't as comfortable, but I already had a 35 i 1Z, and I didn't find this one to be significantly worse.
I would be grateful for appropriate responses!!!
Translated on 30-10-2026, 11:49.
DariusPolo
Post11-08-2008, 18:17    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
...a 240mm clutch will not fit into your bell housing.
Translated on 30-10-2026, 11:50.
BM
Avatar-BM
Post11-08-2008, 21:34    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
Look at this: http://www.valeoservice.com/html/deutschland/de/produits.focusdetail.php?wid=8033240644576A5BABBFDC
3B5 AJM
trebor
Post12-08-2008, 18:06    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
Thank you in advance for the answers.
So, in this case, the topic of the 240 clutch is closed.
What would happen if I were to switch back to the 228 EMS system?
@BM
Do you know how much the Valeo set costs and how many Nm it can handle?
Translated on 30-10-2026, 11:51.
BM
Avatar-BM
Post12-08-2008, 23:02    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
@BMViewing profile: BM
Unfortunately, no, I only stumbled upon the fact that Valeo offers something like that just yesterday.
@Partial clause
For you, figuring that out shouldn't be a problem.
3B5 AJM
obelix2054
Post13-08-2008, 10:53    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
Enjoy your meal.
Valeo Part Number: 826317
List price: €569 net.
(I'm assuming we're talking about a G4 model from 1997-2000.)
Obelix
Translated on 30-10-2026, 11:52.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-08-2008, 12:50    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
You're right, Obelix. The VALEO Premium Kit 826317 costs around €397, plus shipping.
(including VAT)
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 30-10-2026, 11:53.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-08-2008, 13:16    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
Valeo News:
Die 228 er überträgt bis 305 NM ist auch in dem 1,8 Turbo verbaut und wird mit keinen oder nur geringen Schwingungsdämpfungseinbußen unter ca 1900 1/ min mit dem EMS verbaut und hält. Bis jetzt keine negative Rückmeldung an den Vertrieb. Lieferbar immediately.
If it ever becomes obsolete, I also have the part number for the kit without the SM, which is a special order number.
obelix2054
Post13-08-2008, 13:24    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
Hello.
@ teileklaus
Translated on 30-10-2026, 11:54.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-08-2008, 13:51    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
Okay, I'll sell them to you for 460.- icon_biggrin.gif, and also include the Top Valeo Service Info.
trebor
Post13-08-2008, 18:28    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
@ teileklaus
So, could I combine the Valeo kit (without the SM) with a 228 EMS (G60, VR6, or 1Z) and then install it in my ASV?
If so, what is the cost of the kit without the SM (presumably referring to a specific module or component)?
Translated on 30-10-2026, 11:55.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-08-2008, 20:08    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
trebor wrote:
@ partial exam
If so, what is the cost of the kit without the SM?
If it's a problem child, take the whole thing, just like that! That's the only way to make sure it lasts.
Edit: The clutch kit without the SM component is €352, minus 40% including VAT, plus shipping.
Translated on 30-10-2026, 11:56.
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post19-08-2008, 10:48    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
teileklaus wrote:
trebor wrote:
@ partial exam.
Edit: Only the clutch kit without SM = €352, minus 40%, including VAT, plus shipping
I'm interested in the clutch kit, but without the flywheel, as I already have a 1Z flywheel installed.
Can you determine if the pressure plate/friction disc is compatible with a genuine VW 1Z flywheel?
Thank you and best regards.
Jens.
Translated on 30-10-2026, 11:57.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post19-08-2008, 17:16    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
Maybe someone has already installed this? Please let me know.
Translated on 30-10-2026, 11:58.
DieselBär30x
Avatar-DieselBär30x
Post19-08-2008, 20:31    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
Uuuuhhhhh, what are my old and watery eyes reading???
...why didn't I know anything about it until now? Because I'm ignorant, yes, yes, I know icon_cool.gif.
FINALLY, a decent alternative solution for everyone who has suffered from (or been healed from? *g*) ZMS - like me *meld*.
@ KlausiMausi, what would the "Premium Kit" from Valeo cost for my T5, manufactured in 2003 (engine code: AXC = 1.9 PD-TDi, 63kW + chip & gearbox code: FJJ = 5-speed manual), and is it even available for this (rather rare...) model?
The Valeo homepage, including the "Online Parts Catalog" (...why does that make me think of ATE? *laugh*) unfortunately offers very little explicit information *sigh*. The US page has more content, but even there, it's difficult to find information for engines with a displacement of less than 5.7 liters icon_rolleyes.gif.
I'd be happy to send you the exact details via private message if it looks like availability might be good.
Thank you in advance, and greetings from Munich!
Translated on 30-10-2026, 11:59.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post19-08-2008, 21:09    Subject: Dual-Mass Flywheel: Benefits & Explained Quote
FINALLY, a decent alternative solution for everyone who has suffered from (or been healed by, *g*) ZMS - like me *meld*.
Just slow down with the nicknames, there's also a user named Klausi! icon_lol.gif
I'm not a Sachs expert, and I'm not sure if this will work with a 1Z flywheel.
The above-mentioned specific application with the specified number is not suitable for every PD motor.
For your T5, I found a Sachs clutch with a 228 mm diameter (part number 3000970017) that can be used, and also a LUK clutch with a 230 mm diameter (SAC?), but it would need to be used with a different flywheel.
Then, under LUK, there's a 230 mm SAC 623308200, and it's possible that this is just a different LUK part number for the same SAC clutch.
Translated on 30-10-2026, 12:03.
No new posts Defective Dual Mass Flywheel: Symptoms & Repair Diesel Engine Technology
No new posts Two-Mass Flywheel Error Images Diesel Engine Technology
No new posts Two-mass flywheel end of life Transmission, Chassis, Body & Interior
No new posts AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Diesel Engine Technology
