Car Won't Start? Troubleshooting Guide
hoepfelchecker
Post13-12-2009, 12:43    Subject: Car Won't Start? Troubleshooting Guide Quote
...Hello.
I installed an aftermarket heated seat system, including the entire wiring harness, and now the engine won't start... I have a 1.9 diesel engine... I'm desperate... what could be the problem?
...there is no error message...
...I just noticed that the glow plug unit isn't working before I try to start the engine... it can't be due to the recent modifications, right???
Translated on 17-09-2026, 1:46.
Post13-12-2009, 12:46    Subject: Car Won't Start? Troubleshooting Guide Quote
Okay, have you checked the basics? Is the battery dead? Does the interior lighting turn off when you try to start the car?
...I just noticed that the glow plug unit isn't turning on before you start the engine
More likely, the battery is drained if the starter motor isn't turning. I think your seat heater might also be heating up while the car is stationary.
Translated on 17-09-2026, 1:47.
hoepfelchecker
Post13-12-2009, 12:49    Subject: Car Won't Start? Troubleshooting Guide Quote
No, none of that is the case... as I said, the preheating unit isn't activating. Could it be related to terminal 30, from which I took the positive connection for the seat heater?
Translated on 17-09-2026, 1:48.
Post13-12-2009, 12:56    Subject: Car Won't Start? Troubleshooting Guide Quote
Then you should probably provide some more information about the vehicle, the modifications, and things that have already been tested.
hoepfelchecker
Post13-12-2009, 13:16    Subject: Car Won't Start? Troubleshooting Guide Quote
...is a 4-door Golf TDI...
Yesterday, I installed a wiring harness for the seat heaters, and since then, the car won't start because the glow plug unit isn't activating when I turn the ignition key.
Translated on 17-09-2026, 1:49.
Post13-12-2009, 13:25    Subject: Car Won't Start? Troubleshooting Guide Quote
I assume this is only indirectly related to the wiring harness installation. You must have connected the cables to the potential distribution block in the fuse box, right? If so, I would say that relay 109 is faulty and is no longer switching due to your tinkering. Relay 109 is known for having cold solder joints, and is often a source of errors. Just try bridging the load circuits of this relay; if it then works, you'll know what the problem is. If it doesn't work, you can rule it out.
Translated on 17-09-2026, 1:50.
hoepfelchecker
Post13-12-2009, 13:39    Subject: Car Won't Start? Troubleshooting Guide Quote
...this relay isn't located in the fuse box, but rather in a socket underneath the steering wheel, where I screwed the positive wire to terminal 30, right?
Post13-12-2009, 13:45    Subject: Car Won't Start? Troubleshooting Guide Quote
Yes, that's what I mean. On the relay holder, there are also fuses. I expressed myself a little clumsily above. icon_redface.gif
Translated on 17-09-2026, 1:51.
hoepfelchecker
Post13-12-2009, 13:48    Subject: Car Won't Start? Troubleshooting Guide Quote
...and what should I do next?
So, is it not at terminal 30 where I'm connecting the positive wire, or what?
Translated on 17-09-2026, 1:52.
Post13-12-2009, 13:52    Subject: Car Won't Start? Troubleshooting Guide Quote
...and how am I supposed to proceed now?
Read what I've written and do it.
hoepfelchecker
Post13-12-2009, 13:54    Subject: Car Won't Start? Troubleshooting Guide Quote
...hmm, yes, and how do I handle the bridging?
Translated on 17-09-2026, 1:53.
Post13-12-2009, 14:12    Subject: Car Won't Start? Troubleshooting Guide Quote
Take a piece of cable, strip the insulation from both ends, and insert it into the contacts of the load circuit. But please don't ask me now how to strip a cable. icon_wink.gif
schrauber2904
Post13-12-2009, 14:13    Subject: Car Won't Start? Troubleshooting Guide Quote
"Remove the relay and first check if there is voltage at terminal 30. If there is, then bridge terminal 30 to terminal 86."
Post13-12-2009, 14:15    Subject: Car Won't Start? Troubleshooting Guide Quote
schrauber2904 wrote:
if so, then you bridge terminal 30 to 86.
Terminal 86, according to DIN standards, is the control terminal on a relay. Terminal 87 is the load terminal. However, this is also usually indicated on the relay itself.
Translated on 17-09-2026, 1:54.
hoepfelchecker
Post13-12-2009, 14:34    Subject: Car Won't Start? Troubleshooting Guide Quote
Okay, I've bypassed it now, but unfortunately, that's not leading to any results either; the engine still won't start.
hoepfelchecker
Post13-12-2009, 14:39    Subject: Car Won't Start? Troubleshooting Guide Quote
...Thank you everyone, the problem is now solved... Fuse 29 was not quite properly inserted icon_sad.gif now it's working again.
Translated on 17-09-2026, 1:55.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts V6 TDI AKN springt nicht mehr an Diesel Engine Technology
No new posts Audi A6: Engine Won't Start - Troubleshooting Guide Diesel Engine Technology
No new posts Q7 4.2 TDI springt nicht mehr an Diesel Engine Technology
No new posts 1Z Won't Start: Troubleshooting & Fixes Diesel Engine Technology
