STG09 Label File for Golf GTI 2009
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
da.kapo
Post08-12-2009, 21:33    Subject: STG09 Label File for Golf GTI 2009 Quote
I am looking for the label file for the engine control unit (ECU) with identification number 09 and a 30-byte coding for a 2009 Volkswagen Golf GTI. I am using the VCDS system.
Thank you.
Christian.
Translated on 25-09-2026, 1:56.
Post08-12-2009, 22:46    Subject: STG09 Label File for Golf GTI 2009 Quote
Then, could you please give us the part number?
Post09-12-2009, 9:03    Subject: STG09 Label File for Golf GTI 2009 Quote
... and which version of VCDS you are using. The current version is 908.1.
da.kapo
Post09-12-2009, 20:17    Subject: STG09 Label File for Golf GTI 2009 Quote
My VCDS version is 908.1.
The part number is as follows (excerpt from the scan):
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 09: Body Control Module (J519)
Label file: RKS\1K0-937-08x-09.clb
Part number SW: 1K0 937 087 D, Hardware: 1K0 937 087 D.
Part: BCM PQ35 H 103 0541
Revision: 00103 AE
Encoding: 40180A3A98251A00408800847400092443550088736D8D60648000200000
Operating number: WSC 01357 011 00200
Part number: 1K1 955 119 E
Component: Wiper 04100 21 0501
Encoding: 009795
Part number: 1K0 955 559 AH
Component: RLS 061009 05 54 0402
Encoding: 0330AD
However, the label file cannot possibly be correct, as it does not display the complete 30 bytes using LCode.exe.
Thank you for your help.
Christian.
Translated on 25-09-2026, 1:59.
Post09-12-2009, 22:43    Subject: STG09 Label File for Golf GTI 2009 Quote
The label file, however, cannot possibly be the correct one, as it does not display the complete 30 bytes using LCode.exe.
but what? Please provide more details...
Translated on 25-09-2026, 2:01.
da.kapo
Post10-12-2009, 20:10    Subject: STG09 Label File for Golf GTI 2009 Quote
Hello.
Unfortunately, I don't have access to the vehicle right now, so I can't take any screenshots of the LCode output. If I remember correctly, the output stops at byte 16. The remaining bytes are not decoded into plain text.
It should also be possible to display the encoding using LCode offline. Unfortunately, I haven't been able to achieve this.
Christian.
Translated on 25-09-2026, 2:02.
Post11-12-2009, 8:27    Subject: STG09 Label File for Golf GTI 2009 Quote
Wouldn't it also be possible to display the LCode encoding offline?
Why "should" it be that way?
That's precisely why they are .CLB files, meaning they are encrypted, so they cannot be easily read or widely distributed.
If you really need it, meaning if it's actually connected to the car, then it can be decrypted icon_smile.gif.
Translated on 25-09-2026, 2:03.
da.kapo
Post11-12-2009, 16:54    Subject: STG09 Label File for Golf GTI 2009 Quote
Okay, then it won't work offline.
It was just a thought...
How can I proceed with my actual problem, which is to display the 30 bytes of STG09 in plain text or bit-granular format, with the corresponding mapping?
Translated on 25-09-2026, 2:04.
da.kapo
Post13-01-2010, 20:37    Subject: STG09 Label File for Golf GTI 2009 Quote
Happy New Year!
Specifically, in LCODE, bits are marked with "1", but there is no plain text display.
For example, if the binary value 01110100 is located in byte 12, the corresponding plaintext is:
BIT2 x "Manually activate 'Coming Home'," and BIT5 x "Footwell lighting..."
What about the plain text display of the other bits? In this case, bits 4 and 6 are also set to 1.
The label file is not complete here. Many settings of the control unit are described on the web, which VAG COM or LCODE do not resolve into plain text.
Please help me.
Thank you.
'icon_wink.gif'
Christian.
Translated on 25-09-2026, 2:05.
No new posts BLS Label File: Guide & Download On-Board Diagnostics (OBD)
No new posts Problems with label file in 607.3 On-Board Diagnostics (OBD)
No new posts Audi C4 Engine Control Label File: V6 (12V) AAH On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. EPB Problem: Passat 3C, 2009 Model Transmission, Chassis, Body & Interior
