1Z Engine Problems: Troubleshooting & Repair
chli1976
Post26-01-2010, 18:28    Subject: 1Z Engine Problems: Troubleshooting & Repair Quote
I have a Golf III 1Z with a jerking/stuttering issue in 4th and 5th gear.
So, I disassembled, cleaned, and reinstalled the metering unit once, and adjusted the injection amount to 6mg per stroke. I also set the throttle valve travel to 0.72V when the ignition is on.
However, the stuttering is still present. I then read through all the threads about stuttering problems here on the forum.
I checked the needle valve lifter, which was running at 3000 RPM. I tapped it lightly with a screwdriver, but there was no change in the engine's operation, so it seems to be okay.
Today I drove with the speed sensor disconnected, and sure enough, the jerking is gone. There are still some slight fluctuations under light loads, but the VCDS software indicates that the torque cutoff feature should be working.
The posts suggest that in this case, with this symptom and a disconnected tachometer sensor, the problem might be with the quantity control unit. Has anyone successfully tried this? Replacing the quantity control unit and then the jerking stops.
VCDS
Translated on 19-09-2026, 16:31.
Karma: +1361 / -0   Thank you, like it!
Post31-01-2010, 10:12    Subject: 1Z Engine Problems: Troubleshooting & Repair Quote
You just cleaned the point machine, right? Just to be sure: was the rotating magnet easy to turn on its own, and did it have enough clearance after the electromagnet was installed? Was the point machine heavily contaminated?
The values for the MSW sensor and the injection amount should be fine.
If the jerking occurs only sporadically, loose connector contacts may also be the cause (e.g., connections in the engine compartment). Clean them with cotton swabs and contact cleaner or alcohol.
Please check the resistance values of the chemical injection skid (CIS) and the resistance values of the lines from the CIS to the pump. The contacts on the round connector of the ESP cable are counted counter-clockwise. Contact 1 to 3: 4.9 - 7.5 Ohms, Contact 2 to 3: 4.9 - 7.5 Ohms, Contact 4 to 7: 0.4 - 1.1 Ohms.
Translated on 19-09-2026, 16:33.
chli1976
Post31-01-2010, 11:07    Subject: 1Z Engine Problems: Troubleshooting & Repair Quote
Drehmmagnet ist leichtgängig und hat genügend Luftspalt. Späne waren zwar drinnen, hatte aber schon schlechtere. Ruckeln tritt immer auf im, am besten spürbar im 4. und 5. Gang.
Unfortunately, I no longer have the car here to measure it.
VCDS
Translated on 19-09-2026, 16:34.
No new posts Gentle shaking Diesel Engine Technology
No new posts Why is only 1Z stuttering? Diesel Engine Technology
No new posts jerky automatic transmission Transmission, Chassis, Body & Interior
No new posts Passat 1.9 TDi AVF 130PS - experiencing vibrations/jerking Upload
