Empty Tank Problems: Troubleshooting & Solutions
MarkusAFN
Post03-03-2003, 15:43    Subject: Empty Tank Problems: Troubleshooting & Solutions Quote
Last week, my fuel gauge icon_evil.gif completely misled me! It showed about halfway to empty, but the car was already hard to start in the evening. The next morning, it wouldn't start at all. I had to go to the gas station, get a canister, etc....
After a while (several minutes) of gurgling, it started up again (I always thought it would self-bleed and start up much faster!).
Since then, this has happened to me three times: I was stopped at a traffic light, for example, and the engine suddenly stalled! Each time, I had to struggle with the starter for about 20 seconds to get it started again.
What could be the reason for that?
I suspect there are still some air bubbles trapped in the fuel filter.
Volkswagen Golf 3 AFN, 153,000 km.
Translated on 25-08-2026, 16:56.
Post03-03-2003, 16:10    Subject: Empty Tank Problems: Troubleshooting & Solutions Quote
It's quite likely that your ESP is sucking in a lot of air instead of diesel... there's been a lot written about this already.
-> Search function
Translated on 25-08-2026, 16:58.
Post03-03-2003, 18:04    Subject: Empty Tank Problems: Troubleshooting & Solutions Quote
Hi Rainer,
The symptomatology suggests this direction. But how and why can so much air still be sucked in, even "long" after the refilling, causing the engine to stall?
In order for this to happen, the pump needs to be approximately half empty, as I know from repeatedly opening the pump and previously "siphoning" out the diesel.
Once more than about half of the diesel fuel is in the tank, it starts up as usual and runs smoothly.
The engine will briefly "stumble" at idle only when the internal pressure in the pump reaches its normal level (i.e., when all the air has been purged), because the fuel injection timing then needs to be readjusted.
Can running a fuel system dry lead to leaks that later continuously draw in air icon_eek.gif?
To me, the "empty tank-refill-sludge-swirl-filter seal" theory seems more plausible so far.
Only then would a significant lack of performance be noticeable icon_question.gif.icon_question.gificon_question.gif
Translated on 25-08-2026, 16:59.
Post03-03-2003, 18:34    Subject: Empty Tank Problems: Troubleshooting & Solutions Quote
I'm leaning more towards a leak in the fuel system, which would be more noticeable when the tank is relatively empty.
Translated on 25-08-2026, 17:01.
haehnlein
Post04-03-2003, 23:13    Subject: Empty Tank Problems: Troubleshooting & Solutions Quote
ulf wrote:
To me, the "empty-travel-night-refueling-sludge-swirl-filter tight" theory seems more plausible so far.
Only then would a significant lack of performance likely be noticeable icon_question.gif
I can also confirm that icon_exclaim.gif. There can be quite a bit of buildup in the tank, so you should replace the fuel filter icon_exclaim.gif.
I can also confirm the leak theory icon_exclaim.gif. If I only have about 4 liters left in the tank, then large amounts of air bubbles go to the ESP icon_exclaim.gif.
My fuel gauge (Passat 1Z 1995) also shows incorrect values, approximately 10 liters off: Then, the next question is, how does one adjust the fuel sender icon_question.gif icon_confused.gif?
Best regards, Christian.
Translated on 25-08-2026, 17:02.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Empty Tank? Faulty Pump? Get Help Now! Diesel Engine Technology
No new posts Car Starting Problems with Low Fuel? Diesel Engine Technology
No new posts Ford Mondeo: Won't Start After Empty Tank? On-Board Diagnostics (OBD)
No new posts Tank Vent-Ventilation Diesel Engine Technology
