TDI V6: Dynamic Injection Timing AKN
Frank F.
Post28-02-2003, 13:11    Subject: TDI V6: Dynamic Injection Timing AKN Quote
Hello everyone!
What should the settings be for the dynamic and static injection start timing on the AKN engine?
My current status is:
Dynamic: -14°
Static: +3.2°
Ist das korrekt? Mein Problem ist, daß er ab ca 3500 upm nicht mehr so gut geht. (Endgeschwindigkeit lt. Speedometer reading: 200.
Best regards, Frank.
Translated on 06-10-2026, 18:59.
Michael II
Post28-02-2003, 14:08    Subject: TDI V6: Dynamic Injection Timing AKN Quote
Hello Frank,
The target values are located in the "Troubleshooting and Instructions" section.
Under what conditions did you determine these values?
Have you already read the error codes? Have you already performed a diagnostic test drive?
If so, please post the results.
Tschüss
Michael II
Translated on 06-10-2026, 19:00.
Frank F.
Post28-02-2003, 17:17    Subject: TDI V6: Dynamic Injection Timing AKN Quote
Hello Michael!
The values were measured using a Bosch tester while the engine was stationary and at operating temperature. Unfortunately, I can't make any use of the values from the target value list, as the Bosch device seems to convert them and display them in plain text.
I haven't conducted any measurement runs yet, as the testing device is not a mobile one.
'Could there be a problem with the mass airflow sensor? I drive quite a bit in short distances (12 km to work and back), could that be the cause?'
Questions upon questions, I know!
Translated on 06-10-2026, 19:01.
No new posts VW Dynamic High Beam Assist Speed Threshold Electrical Systems, Vehicle Electronics, Multimedia
No new posts AEL Dynamic Start: Volvo Application Diesel Engine Technology
No new posts VCDS Error Codes related to Dynamic LWR 0003 On-Board Diagnostics (OBD)
No new posts Adjustable Injection Start: Not Configurable Diesel Engine Technology
