BMW 325tds: Starting Problems & Solutions
libelle
Post21-02-2003, 12:13    Subject: BMW 325tds: Starting Problems & Solutions Quote
Hello.
I own a 1998 325tds.
When the engine is hot or cold, you need to let it run for at least 20 to 30 seconds before starting.
until the engine starts.
Once the engine is running, there is no smoke, the performance is good, and the fuel consumption is good.
I suspect the engine temperature probe is defective. Has anyone experienced this?
reference value in ohms for me.
Best regards, Werner, from South Africa.
Translated on 03-09-2026, 0:22.
Post21-02-2003, 20:21    Subject: BMW 325tds: Starting Problems & Solutions Quote
Hi Werner,
Okay, let's talk about your problem:
The injection system in your car is almost identical to that of the VW VP TDI engine (except for having 6 cylinders). I think you might have a problem with the timing of the injection pump.
On the main page of Rainers Turbodiesel's website, you will find a quite good explanation of how to adjust the injection pump without expensive workshop tools.
http://www.dieselschrauber.de/esp.html
I think your German language skills are good enough to understand most of it.
Best regards from cold Germany.
Translated on 03-09-2026, 0:23.
diesel.gustav
Post23-02-2003, 1:03    Subject: Diesel Mechanics: Now Available Worldwide! Quote
Deleted upon request.
Translated on 03-09-2026, 0:24.
Post23-02-2003, 9:59    Subject: Diesel Repair: Now Available Worldwide! Quote
diesel.gustav wrote:
and the description of the setup using "DIY methods" is so verbose and therefore so complicated that I (with good German and system knowledge) have problems understanding the procedure.
Hello Gustav.
If even people like you are having comprehension problems, I will probably have to revise the text again... thank you for the "subtle hint" icon_redface.gif.
Translated on 03-09-2026, 0:25.
libelle
Post01-03-2003, 6:46    Subject: BMW 325tds: Starting Problems & Solutions Quote
Hello everyone, thank you, I've found the error.
Best regards from South Africa.
werner
Translated on 03-09-2026, 0:26.
No new posts 325tds E36 Kalt / Warmstartschwierigkeiten Diesel Engine Technology
No new posts BMW 325tds automatic hatt Leistungsfehler Diesel Engine Technology
