BMW 325tds Starting problems
libelle
Messaggio21-02-2003, 12:13    Oggetto: BMW 325tds Starting problems Traduzione in corso...
I have a 325tds 1998 Model Year
when engine is hot or cold u have to wind started for at least 20 to30 sec
till engine starts
once engine runs no smoke performance fine fuel cons good
I suspect the engine temp probe to be defective ha sany one got
reference value sin ohms for me
Viele Gruesse werner aus Südafrika
Messaggio21-02-2003, 20:21    Oggetto: BMW 325tds Starting problems Traduzione in corso...
Hi Werner,
Well lets talk about your problem:
The injection system of yor car is nearly the same as in the VW VP TDI engine (exept of having 6 cylinders). I think you have a problem with the injection pump timing.
On the mainpage of Rainers Turbodiesel page yo will find a quite good explanation of how to adjust the injection pump without expensive workshop tools.
http://www.dieselschrauber.de/esp.html
I think yout German language is good enough to understand most of it.
Viele Grüße aus dem kalten Deutschland.
Kind regards Bertil
diesel.gustav
Messaggio23-02-2003, 1:03    Oggetto: Dieselschrauber.de goes worldwide! Traduzione in corso...
[Traduzione in corso...]Auf Wunsch gelöscht
Messaggio23-02-2003, 9:59    Oggetto: Re: Dieselschrauber.de goes worldwide! Traduzione in corso...
diesel.gustav ha scritto:
und die Beschreibung der Einstellung mit "Heimwerkermitteln" so wortreich und damit so kompliziert, daß ich (mit guten Deutsch- und Systemkenntnissen) Probleme habe, die Vorgangsweise zu verstehen.
Hallo Gustav
wenn selbst Leute wie Du Verständnisprobleme haben, werde ich den Text wohl nochmal überarbeiten müssen . . . danke für den "Wink mit der Blume" icon_redface.gif
libelle
Messaggio01-03-2003, 6:46    Oggetto: BMW 325tds Starting problems Traduzione in corso...
[Traduzione in corso...]hallo alle danke fehler gefunden
gruss aus Suedafrika
werner
Nessun nuovo messaggio 325tds E36 Kalt / Warmstartschwierigkeiten Tecnologia Motori Diesel
Nessun nuovo messaggio BMW 325tds automatic hatt Leistungsfehler Tecnologia Motori Diesel
