Uneven acceleration from 3000 RPM
Fetz
Post03-03-2003, 14:39    Subject: Uneven acceleration from 3000 RPM Quote
icon_question.gif Passat TDI, year of manufacture 1999, engine code AHU.
The engine stops accelerating consistently around 3000 RPM.
Maximum speed is reached later than expected.
No errors in memory, the inspection found nothing.
Thank you for any information...
Best regards, Fetz.
Translated on 10-07-2026, 10:51.
rl2664
Post03-03-2003, 14:43    Subject: Uneven acceleration from 3000 RPM Quote
Was wäre, wenn der mass airflow sensor überprüft worden wäre? Just because there's nothing in the memory doesn't necessarily mean it's not faulty.
Ronny.
Translated on 10-07-2026, 10:52.
Michael II
Post03-03-2003, 14:46    Subject: Uneven acceleration from 3000 RPM Quote
Hello Fetz,
There's a lot of information about this problem in the forum. Please search first...
Tschüss
Michael II
Translated on 10-07-2026, 10:53.
Post03-03-2003, 16:21    Subject: Uneven acceleration from 3000 RPM Quote
Michael II wrote:
There is a lot of information about this problem in the forum. Please search first...
...or read and print out the technical article on VAGCOM troubleshooting and present it to the mechanics.
And then, please describe the reaction that followed icon_smile.gif.
Alois
Post04-03-2003, 10:25    Subject: Uneven acceleration from 3000 RPM Quote
@Fetz,
I would borrow a working LMM (laser module) from an acquaintance/friend for testing. It's really quick to remove and replace the LMM – only about 5 minutes. If it then works, you've found the problem.
Translated on 10-07-2026, 10:54.
No new posts Vibration at Acceleration: Causes & Fixes General Tips
No new posts ASZ Full Load Adjustments: 1700-3000 U/min Diesel Engine Technology
No new posts ALH Engine: Performance Issues Above 3000 RPM Diesel Engine Technology
No new posts Audi A4 TDI: Engine Limiting & Smoke Issue Diesel Engine Technology
No new posts Golf 4 TDI: Jerking/Hesitation at 2000-3000 RPM and under... On-Board Diagnostics (OBD)
