Gentle Vibration 1Z: New Idea
Igor
Post10-03-2003, 11:24    Subject: Gentle Vibration 1Z: New Idea Quote
Hello fellow enthusiasts,
After fixing the severe jolting by replacing the needle lift sensor, there's still a slight vibration remaining.
After trying all the suggestions related to this issue, disconnecting the speed sensor finally eliminated the jerking. So, once again, the problem is with the fuel quantity meter. In my 1Z, the jerking occurred between 2100-2500 RPM. Using a can of LM Diesel Cleaner shifted the 'jerking range' to 1800-2100 RPM. That seemed like the right approach. So, I invested the 99€ and had ATU perform a diesel system cleaning. Unfortunately, it didn't do anything.
Biodiesel has a strong cleaning effect! Since I'm already planning to have the fuel pump replaced or the fuel tank serviced, I could try running 1-2 tanks of biodiesel. I'm aware that neither the fuel pump seals nor the fuel lines are suitable for this. I don't intend to use biodiesel permanently, but rather to clean the fuel system with it. One tankful lasts about 14 days based on my driving habits. I'm not concerned about the fuel pump seals, but I want to avoid the fuel leaking onto the road.
Are there any experiences with this yet?
Igor.
Translated on 27-09-2026, 15:32.
DocSnydor
Post10-03-2003, 12:10    Subject: Gentle Vibration 1Z: New Idea Quote
I've also been thinking about biodiesel. icon_confused.gif There's not much to lose, really.
I heard that rapeseed oil is more effective! And it's not as harsh.
Good luck with the attempt!
I see that NVE is also experiencing the same problem. How is your 1Z engine doing otherwise? I'm also having a significant lack of power (boost pressure is fine, injectors are new, EGR is disconnected, no soot)...
Translated on 27-09-2026, 15:35.
Post10-03-2003, 13:39    Subject: Gentle Vibration 1Z: New Idea Quote
Hi Igor,
I tried cleaning it with BD (presumably a cleaning product) on my 1Z, but I had no success. In fact, I think that dissolving the deposits with BD might be damaging or making the MSW (likely referring to a mechanical component) difficult to operate (theory: sand in the gearbox...).
The car should not even have been approved by VAG for use with BD. Using BD can damage the tank, the lines, and other parts. BD is particularly "harmful" to rubber and plastic. icon_eek.gif
Please read NVE's post as a supplement.
Translated on 27-09-2026, 15:37.
mhernach
Post11-03-2003, 10:45    Subject: Gentle Vibration 1Z: New Idea Quote
Hello!
I also initially dismissed the 'rücken' at the beginning, didn't think much of it...
'I've been using biodiesel for about 80,000 km in my Galaxy 1.9l TDI (1Z), and the engine misfire is gone. I'm just curious how long it will last, because according to Ford, I'll be responsible for any engine damage caused by it...'
But, as I already mentioned, I am satisfied, and it keeps running and running...
Best regards, Mike.
Translated on 27-09-2026, 15:39.
Post11-03-2003, 10:53    Subject: Gentle Vibration 1Z: New Idea Quote
mhernach wrote:
I'm just curious how much longer it will last, because according to FORD, I will have to bear the cost of a potential engine failure...
That's nonsense... if anything, the fuel injection pump or various hoses would start leaking or break.
It's only slightly cheaper icon_mrgreen.gif.
Translated on 27-09-2026, 15:40.
Igor
Post11-03-2003, 11:56    Subject: Gentle Vibration 1Z: New Idea Quote
Hi DocSnydor,
Aside from the occasional stuttering, the machine runs quite well considering it has 260,000 kilometers on the clock. When it's completely cold, it's hard to get it moving at first, but I've gotten used to that. It's gone after about 1 kilometer.
If I want to keep driving this car for a while longer, I probably have to replace or repair the ESP system, and then maybe the engine will fail. icon_sad.gif
Igor.
Translated on 27-09-2026, 15:41.
DocSnydor
Post11-03-2003, 13:07    Subject: Gentle Vibration 1Z: New Idea Quote
@Igor
Older cars are just money pits... But what can you do? Otherwise, mine is still in top condition. It's 9 years old and has 220,000 km on the clock, which you can't really tell. We could place a bulk order for the VP37 fuel injector from Bosch... icon_biggrin.gif
I had inquired about it back then. Replacing the ESP unit on my Bosch Fritze would cost €1000, including installation... That's quite a sum of money... If only I knew how the car would perform afterwards!
Translated on 27-09-2026, 15:42.
mhernach
Post12-03-2003, 11:11    Subject: Gentle Vibration 1Z: New Idea Quote
The thing about the hoses is true, it's much cheaper for me. I pay about €0.55 per liter.
Oh, and one more thing, I now have almost 260,000 kilometers on it...
Have a nice day.
Best regards, Mike.
Translated on 27-09-2026, 15:43.
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts New Idea: [Rest des Titels] Diesel Engine Technology
No new posts New cause of stuttering! Diesel Engine Technology
No new posts Gentle shaking Diesel Engine Technology
No new posts AGR Closure XXL - Idea Diesel Engine Technology
