RNS E: 16352 - Steuergerät - Electrical Fault 014 - Defect
paulus
Post02-08-2010, 21:57    Subject: RNS E: 16352 - Steuergerät - Electrical Fault 014 - Defect Quote
Hello everyone,
I have reinstalled the RNS E in my A6 (it had been exported to the previous owner multiple times!!!). I bought and installed a new one through a bookshop.
Everything is fine until this error, which I read out with the VCDS.
Monday, 02 August 2010, 20:44:44:39547
VCDS Version: RKS 908.2
Address 56: Radio Label file: RKS\8E0-035-192-RNSE.lbl
Part Number: 4B0 035 192 P HW: 4B0 035 192 P
Part and/or Version: RNS-E HIGH EU H77 0650
Encoding: 0502313
Errors have been deleted.
1 Error found:
16352 - Control Unit - Electrical Fault
014 - defective - Sporadic
Environmental Conditions:
Error Status: 00101110
Error Priority: 5
Frequency of Errors: 2
Lost Count: 40
Time: 0
Date: 2006.10.06
Time: 09:38:15
Can anyone relate to this?
Greetings, Paul
Wiesel
Post04-08-2010, 13:48    Subject: RNS E: 16352 - Steuergerät - Electrical Fault 014 - Defect Quote
What impact does the error have?
paulus
Post05-08-2010, 19:05    Subject: RNS E: 16352 - Steuergerät - Electrical Fault 014 - Defect Quote
Hello, Wiesel,
I can't identify any errors at this point, except that the installed 9ZF is not functioning correctly. The error described above reappears immediately after the error log file is deleted.
I just bought and installed the Cullmann phone interface (Cullmann) from the auction. The encoding is also correct.
As mentioned, the RNS E system works perfectly, except for the phone functionality. Could this error be due to the previous thefts and the resulting repaired wiring harness?
Greetings, Paul
No new posts Electric auxiliary heater, smell of burning, Audi A4 A5 Q5 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document MKB AKQ, defective timing belt tensioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spark Plug Problem: Electrical Fault Diagnosis On-Board Diagnostics (OBD)
No new posts NOX Bank1 P2200 - Electrical Fault On-Board Diagnostics (OBD)
No new posts Faulty T4 engine control unit, 2.5 TDI ACV On-Board Diagnostics (OBD)
No new posts Faulty Control Unit: Diagnosis & Repair On-Board Diagnostics (OBD)
