Error 01130 ABS operation on Audi S3
Jochen912
Post16-07-2010, 16:44    Subject: Error 01130 ABS operation on Audi S3 Quote
My diagnostic scan on my Audi S3 (8L), manufactured in 2001, indicates an implausible signal in the ABS system, error code 01130.
After unplugging the connector and plugging it back in, the error unfortunately persists, even after clearing the error codes. Although the error is no longer detected, the warning light remains on.
I had this problem once before, about a year ago, and pulling out the plug helped.
01130
ABS operation, implausible signal.
Electrical disturbances caused by external interference sources (high-frequency radiation).
Interruption, short circuit to positive or ground in the wiring.
ABS control unit J104 is defective.
Does anyone have any ideas about what else I could try or test here, or is it really the control unit that's broken this time?
Can the control unit be replaced individually, or does the entire ABS unit, which the control unit is attached to, need to be replaced?
geht nicht, gibt's nicht!!!
Post16-07-2010, 18:48    Subject: Error 01130 ABS operation on Audi S3 Quote
Occasionally, the ABS connector can become corroded. Another common issue in the 8L model is the fuse box located directly on the battery. It causes intermittent connections or resolves them with the most unlikely errors.
Jochen912
Post19-07-2010, 20:06    Subject: Error 01130 ABS operation on Audi S3 Quote
Best regards, Rainer
As I said, I already removed the plug and checked it, and it looks perfect.
I also checked the fuse box, but it looks brand new, in perfect condition.
Hmm..., so it seems that the control unit is indeed broken icon_sad.gif.
Does anyone else have any ideas about what else I could do or check?
No new posts Audi A4 documentation, fault in the secondary air system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4: Airbag System Error - Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Fan Error: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine diesels, and it's jerking while running! Diesel Engine Technology
No new posts Seat Altea 5P rear wiper out of order Electrical Systems, Vehicle Electronics, Multimedia
No new posts Variable Speed Fan: Always Running. Diesel Engine Technology
No new posts DPF Removal & Operation: Has Anyone Tried It? Diesel Engine Technology
