Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Post14-06-2010, 20:25    Subject: Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA Quote
Problem: With the 2.0 TDI CR engines with the engine codes CBAB, CBBB, CBDC, CBAA, and CBBA, the coolant level indicator lights up even though the coolant level is normal and there is no loss of coolant.
When the engine is cold, after opening the coolant reservoir cap, the fluid level may reach the normal level in the coolant reservoir.
Cause: Overly flexible coolant hoses.
Solution: Stickers for lower 'min' coolant level and modified container lid 3C0 121 321
Ratings - Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CBAB: Interpreting VTG Error Codes Diesel Engine Technology
No new posts CBAB 2.0 TDI VW Tiguan Turbocharger Adjustment Diesel Engine Technology
No new posts VTG Valve Diagnosis: CBAB Unit Repair On-Board Diagnostics (OBD)
No new posts AGR throughput too small... Passat CBAB engine Diesel Engine Technology
