Gremlin Schrauber
Joined: 08/18/2005 Posts: 396 Karma: +92 / -0 Location: Grainet 2000 Audi A4 Avant  Premium Support
22-06-2010, 13:55 Subject: PD-TDI: High Revs? Troubleshooting Guide. |
Hello for now;
My girlfriend's Lupo, manufactured in 1999, with a 1.4L TDI engine (75 hp, AMF engine type), was tested today at the vehicle inspection station (using a Gutmann device).
According to the information provided, the maximum allowable speed should be 4700 RPM; however, I am sometimes exceeding this by approximately 35 RPM.
otherwise:
Top-quality, in the best sense - blurring, etc.
My question:
I've searched, but I haven't found anything specific.
The typical maximum engine speed for TDI engines is generally around 5000 RPM, as is commonly known.
-Is the above-mentioned speed setting correct?
-The tachometer signal is taken from the battery terminals. Are there any alternatives for the PD (Performance Data) system? (According to my research, this could be a potential source of error, and yes, it has been switched to a 3-cylinder engine).
-If this is indeed too high, how can it be fixed? No tuning, nothing at all, it can't be more original than this... (the only thing that's not original is a completely cheap exhaust system from IMASAF).
Regarding the vehicle itself:
Approximately 158,000 km, very low oil consumption (0.5 liters per 15,000 km), single turbocharger.
P.S.: He eventually passed the ASU exam, but only on his third attempt...
Translated on 15-09-2026, 7:42.
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
22-06-2010, 15:15 Subject: PD-TDI: High Revs? Troubleshooting Guide. |
Hey, what's the problem? The TÜV inspector just sets the maximum RPM higher, and that's it, right? Or is there more to it?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 15-09-2026, 7:44.
Profile PM Email Garage |
Gremlin Schrauber
22-06-2010, 15:42 Subject: PD-TDI: High Revs? Troubleshooting Guide. |
He did, yes - he just didn't want to write it "loudly"...
The data is stored in the tester (depending on the vehicle/engine), including the target RPM. However, the actual RPM reading was not correct.
That's actually what worried me a little, whether it's actually "correct" or reliable.
I need to dig up those old ASU reports...
Translated on 15-09-2026, 7:45.
Profile PM Garage |
22-06-2010, 16:50 Subject: PD-TDI: High Revs? Troubleshooting Guide. |
You can compare the engine speed by checking the OBD port.
I don't think it's that easy to adjust.
