Login Error: A4 2.0 TDI - Troubleshooting Guide
anderl85
Post27-06-2010, 19:36    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
First of all, greetings to everyone.
I'm brand new to this forum, although I've been actively exploring it for several days already.
Recently, I became the proud owner of a "Diagnosetool Profi CAN USB," and of course, I've already used it for all sorts of things (mostly useful ones).
Now I wanted to lower the idle speed in the MSG, as it seems a bit too high. Unfortunately, this apparently only works with a login.
The control unit did not accept the login "12233", which is known to be used in some cases. However, I haven't found any information online or in this forum suggesting that there are other logins for the 4-cylinder diesel engines.
The vehicle should not have any chip tuning or other modifications, as it is a former lease car from Siemens.
Here are some more details:
First registration: 03/2006.
Address 01: Engine Control Module
Label file: DRV\03G-906-016-BLB.lbl
Part number SW: 03G 906 016 JD, HW: 028 101 265 4.
Part number: R4 2.0L EDC G000SG 9905.
Revision: --H02--- Serial Number:
Encoding: 0000072
Operating number: WSC 49930 141 78974
No error codes found.
Readiness: 0 0 0 0 0
It would be great if you could enlighten a newbie...
Here's another piece of information: VCDS version: DRV 908.2.
Translated on 27-07-2026, 17:03.
mullemaus
Post27-06-2010, 23:30    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
This login is also not set up/intended icon_wink.gif. There are some for these engines, but not this one anymore icon_biggrin.gif.
Translated on 27-07-2026, 17:06.
anderl85
Post27-06-2010, 23:44    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Then your answer will lead to two more questions for me.
Does this have anything to do with this specific engine (16V without a DPF)?
Which login is the correct one then?
"About six months ago, I took my car to the mechanic because I thought it was vibrating too much at idle. I had recently switched from a 1.9 TDI, and in direct comparison, it was extremely noticeable."
The friendly technician then installed a software update for me, but I didn't notice any difference compared to before. Is it possible that the workshop couldn't install new software without logging in?
Translated on 27-07-2026, 17:07.
mullemaus
Post27-06-2010, 23:53    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Is it possible that the workshop was also unable to install new software without logging in?
No icon_wink.gif.
Translated on 27-07-2026, 17:08.
anderl85
Post27-06-2010, 23:59    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Hmm,
On the one hand, it's reassuring that I have the latest software version installed, but on the other hand, icon_sad.gif it doesn't help me at all.
How do I obtain that, or the correct login code? And why doesn't anyone else ask for it here?
Translated on 27-07-2026, 17:09.
mullemaus
Post28-06-2010, 0:07    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
And why isn't anyone else asking about it here?
I think it's because nobody has problems with their idle speed icon_lol.gif icon_wink.gif.
How do I obtain the correct login code?
Are the possible login codes not displayed in the mouse cursor within VCDS? Check with support; they may have more information icon_wink.gif.
Translated on 27-07-2026, 17:10.
anderl85
Post28-06-2010, 0:15    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Well, I don't really understand what "activating" and "deactivating" GRA means, because I have no interest in disabling my cruise control.
Why were the login codes changed?
--> Apparently, I'm talking to an insider icon_biggrin.gif.
Translated on 27-07-2026, 17:11.
Karma: +807 / -0   Thank you, like it!
Post28-06-2010, 7:45    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Translated on 27-07-2026, 17:12.
anderl85
Post28-06-2010, 10:57    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Okay.
Then the next question is:
Wie komme ich ohne Login an besagten Datensatz? VAGDashCAN?
Please tell me there's another way!
Translated on 27-07-2026, 17:13.
Post28-06-2010, 11:25    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Clicking on the file link in VAGCOM would be too easy, wouldn't it?
mullemaus
Post28-06-2010, 21:48    Subject: Login Error: A4 2.0 TDI - Troubleshooting Guide Quote
Ok,
anderl85
No, Rainer means that the 'dataset' refers to the content of the flash memory. icon_wink.gif This can only be read out using hardware/software like Byteshooter.
Translated on 27-07-2026, 17:14.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit (ECU) Login Failed On-Board Diagnostics (OBD)
No new posts WFS Login Code Missing: What to Do? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Q7 3.0 TDI: Regeneration Problems & Solutions Diesel Engine Technology
No new posts N75 Valve Not Activating on VW Passat 2.0 TDI Diesel Engine Technology
