jakobkoester Guest
09-08-2010, 22:07 Subject: Boost Pressure Build-up AFN Engine |
I bought a VCDS license because I think my Passat with the AFN engine is slow.
I just completed this scope run. My speed was 5th gear / approximately 90 kilometers per hour.
Is this a 'typical' pressure buildup?
Jacob.
| Description: |
| Measuring blocks - group 10 |
| File size: |
81.74 KB |
| Viewed: |
1913 times |
Translated on 16-08-2026, 1:12.
09-08-2010, 22:13 Subject: Boost Pressure Build-up AFN Engine |
Incorrect manifest. Please record manifest number 11. However, it already looks somewhat abnormal.
Translated on 16-08-2026, 1:13.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
09-08-2010, 23:02 Subject: Boost Pressure Build-up AFN Engine |
Quote: | | Is that a "normal" pressure build-up? |
Unfortunately not. Please upload the unaltered log file (MWB 11) here so that it can be properly viewed with KDataScope.
Profile PM WWW Garage |
jakobkoester Guest
10-08-2010, 7:57 Subject: Diesel Repair: Amazing People & Expert Service |
Here you can find sections 3, 8, and 11 of the 'MWB' (likely referring to a specific document or standard).
best regards
Jacob.
| Description: |
 Download |
| File name: |
Passat_AFN.xls |
| File size: |
42 KB |
| Downloaded: |
457 times |
Translated on 16-08-2026, 1:14.
10-08-2010, 9:27 Subject: Boost Pressure Build-up AFN Engine |
Quote: | | Please provide the unaltered log file | .
Should I create an Excel chart now, or what?
jakobkoester Guest
10-08-2010, 10:18 Subject: Boost Pressure Build-up AFN Engine |
Wrong link... sorry.
| Description: |
| File size: |
107.65 KB |
| Viewed: |
1478 times |
| Description: |
 Download |
| File name: |
Passat_AFN.xls |
| File size: |
49 KB |
| Downloaded: |
346 times |
Translated on 16-08-2026, 1:15.
10-08-2010, 10:44 Subject: Boost Pressure Build-up AFN Engine |
Why don't you just do what is asked?  You really lose the motivation that way.
Your lambda sensor is either defective or the actual exhaust flow is too low due to obstructions in the intake manifold or exhaust system.
t.klebi Guest
10-08-2010, 12:40 Subject: Boost Pressure Build-up AFN Engine |
Why don't you just do what is asked?  You really lose the desire to do anything.
Perhaps jakobkoester simply didn't understand you. It seems he comes from the Scandinavian region.
t.klebi
Translated on 16-08-2026, 1:16.
jakobkoester Guest
10-08-2010, 12:55 Subject: Best German Restaurants: Find Top Rated Dining |
Thank you for your excellent answer. And I apologize that I didn't understand the questions, but I only studied German for a year in elementary school, and that was 20 years ago.
Sincerely,
Jakob
Translated on 16-08-2026, 1:17.
10-08-2010, 14:32 Subject: Boost Pressure Build-up AFN Engine |
Ah, okay... I hadn't noticed the ".dk" in the email address.
