Recently, I was driving on the highway and wanted to really let my M6 Diesel engine run freely.
Around 180 km/h, there was suddenly a burning smell. Since then, the turbo seems to be largely ineffective. Above 3000 RPM, the turbo still noticeably contributes, but below that, it doesn't work at all.
After the trip, the VTG adjustment was stuck firmly in the closed position.
I checked the turbocharger: There are no signs of mechanical damage, the shaft rotates freely, has no play, and there is no oil in the compressor housing.
I once temporarily removed the VTG unit from the turbocharger exhaust side for testing. The VTG mechanism is working perfectly. However, I found remnants of two large metal discs, each 0.3 mm thick, inside the turbocharger housing.
Originally, these were likely located between the inner housing of the loader and the VTG unit. These remnants blocked the adjustment of the VTG.
