VW Touareg 3.0 TDI Engine Failure Cause?
schlauchdruide
Post30-06-2011, 8:49    Subject: VW Touareg 3.0 TDI Engine Failure Cause? Quote
Overnight, the 6th cylinder became full of coolant and then seized when starting. I removed the glow plug and pushed the water out by turning the engine. After that, it started again.
Is this problem a known issue, and if so, what is the cause of this damage?
Translated on 23-08-2026, 0:50.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post30-06-2011, 16:38    Subject: VW Touareg 3.0 TDI Engine Failure Cause? Quote
Yes, this has happened before, just like in your Touareg. When the engine block was removed, a crack was discovered, and the customer received a new engine.
EDIT: Sorry, I was mistaken. It was actually a 2.8-liter gasoline engine, and the block had a crack, although it was only minor, but there was water loss.
reflexsilber met.
Translated on 23-08-2026, 0:51.
schlauchdruide
Post30-06-2011, 19:49    Subject: VW Touareg 3.0 TDI Engine Failure Cause? Quote
Can you remember exactly where the crack was?
Translated on 23-08-2026, 0:52.
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine failure, cause? Audi 3.0TDI Engine: ASB Diesel Engine Technology
No new posts Engine Failure Causes: What You Need to Know Diesel Engine Technology
No new posts Timing belt, Audi A3 8V1 2.0TDI CRBC and Golf 7 2.0TDI CRLB Diesel Engine Technology
No new posts Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp e... Diesel Engine Technology
