ABS Error 01435: Golf 1J MJ 2001 Repair Guide (Solution)
Michael II
Post07-03-2003, 10:00    Subject: ABS Error 01435: Golf 1J MJ 2001 Repair Guide Quote
ESP control light is on. Error code 01435: Implausible signal received from brake pressure sensor G201.
Cause:
This error only occurs in vehicles equipped with the MK60 braking system and brake light switch No. 1J0 945 511 B. In some vehicles, the brake light switch was not adjusted correctly. When the brake pedal is pressed, the brake light switch must switch to the "activated" position before a pressure of 4 bar is reached in the braking system. If the brake light switch only switches to the "activated" position after 4 bar of pressure, the error code 01435 008 "implausible signal" may be stored in the fault memory. This value can be determined using measuring block 005.
Solution:
A brake light switch that is not properly adjusted may trigger a fault code. The error message will indicate "Measurement block 008: Brake light switch" after the error code. To resolve the issue, please readjust the brake light switch.
Before assembly, fully extend the plunger of the brake light switch.
Pass the switch through the mounting hole, press against the brake pedal, and secure it by turning 45 degrees to the right.
The brake pedal remains in its resting position (not depressed).
Plug in the connector for the brake light switch.
Check brake light function.
Tschüss
Michael II
Translated on 27-10-2026, 15:18.
Ratings - ABS Error 01435: Golf 1J MJ 2001 Repair Guide
No new posts Airbag Error 1317: Polo MJ 2001 Diagnostic Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Automatic transmission error. Gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance loss Golf TDI PD, Year 2001, 115 hp Diesel Engine Technology
No new posts Brake Pressure Sensor G201: Fault 01435-008 On-Board Diagnostics (OBD)
No new posts VW Golf IV: ESP/ABS error On-Board Diagnostics (OBD)
No new posts Golf III TDI AHU: Common Problems & Fixes On-Board Diagnostics (OBD)
