VW Golf TDI starts, then dies
Go to page: 1, 2  Next
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
juster321
Post24-09-2010, 9:16    Subject: VW Golf TDI starts, then dies Quote
Hello everyone.
I'm having a real problem with my Volkswagen Golf 4 1.9 TDI 74kW, manufactured in 2004.
"Sometimes, the car starts but immediately stalls. After that, I have to try starting the engine about 15 to 25 times before it finally runs. Once it's running, it restarts without any problems throughout the day, but sometimes it won't start again the next morning. This problem occurs in the summer when it's 30 degrees Celsius, as well as in the autumn during colder days and nights. I checked the error memory using VAG-COM, but found no errors. I cleaned the throttle body, replaced the diesel filter, and checked various sensors using VAG-COM, but nothing seems to be wrong. Which expert in this field has any other ideas? I would be very grateful for your help."
Translated on 18-07-2026, 1:10.
Post24-09-2010, 9:29    Subject: VW Golf TDI starts, then dies Quote
Did you read out the error codes for the immobilizer?
Translated on 18-07-2026, 1:12.
juster321
Post24-09-2010, 11:20    Subject: VW Golf TDI starts, then dies Quote
Okay, I've checked the immobilizer system. As I said, no error codes are appearing during the diagnostic scan.
Post24-09-2010, 11:45    Subject: VW Golf TDI starts, then dies Quote
Have you already checked the entire fuel system for leaks? Does it get better when the tank is more than half empty?
vwSchrauber
Post24-09-2010, 11:47    Subject: VW Golf TDI starts, then dies Quote
Please check the coolant temperature sensor (G62). In some software versions, a faulty G62 can cause the engine to stall in a specific way: it happens when the system switches from the initial injection phase (with a relatively high fuel injection amount) to idle speed control.
Translated on 18-07-2026, 1:13.
juster321
Post24-09-2010, 11:57    Subject: VW Golf TDI starts, then dies Quote
"I've already checked the fuel lines and they seem to be sealed. It doesn't matter if the tank is full or half-full. G62? I have the manual here, but I can't find anything about it."
juster321
Post24-09-2010, 12:00    Subject: VW Golf TDI starts, then dies Quote
juster321 wrote:
I've already checked the fuel lines, and they seem to be sealed. It doesn't matter if the tank is full or half-full. G62? Where can I find it? I have the manual here, but I can't find anything about it.
I also suspected a vacuum leak, but it wasn't that. That's why I changed the filter, because the O-rings on it can sometimes tear. But as I said, now it only starts sometimes. Could it be that it won't start again tomorrow morning?
Translated on 18-07-2026, 1:14.
vwSchrauber
Post24-09-2010, 12:02    Subject: VW Golf TDI starts, then dies Quote
The G62 sensor is located on the left side (when facing forward) near the water flange of the cylinder head. On the back, it has a two-pin connector with a plastic clip.
Translated on 18-07-2026, 1:15.
Post24-09-2010, 12:15    Subject: VW Golf TDI starts, then dies Quote
In the morning, with a cold engine, the diagnosis is:
- Test the engine control unit (ECU) coolant temperature sensor.
- Test the AI coolant temperature.
- Check the standard outdoor thermometer.
They should all be the same.
Or, according to vwSchrauber's theory, not at all.
Translated on 18-07-2026, 1:16.
juster321
Post24-09-2010, 19:51    Subject: VW Golf TDI starts, then dies Quote
Here's the translation:
"Are those the three sensors that are located to the left, at the front, next to the engine, and all screwed into a 'housing'? Yes, I will test them tomorrow. Thank you very much for your help."
Translated on 18-07-2026, 1:17.
juster321
Post25-09-2010, 7:50    Subject: VW Golf TDI starts, then dies Quote
juster321 wrote:
Those are the three sensors that sit next to each other on the right side, near the front of the engine, all screwed into a "housing"? Yes, I will test that tomorrow. Thank you very much for now.
juster321
Post25-09-2010, 21:09    Subject: VW Golf TDI starts, then dies Quote
I've read some data and I'm posting it here; hopefully, there isn't anything wrong. The temperature reading this morning was correct, but the engine started (it seems to have had a good day today). I just read the data again after driving, and here are the results.
Saturday, September 25, 2010, 9:48:46 PM: 26062
VCDS Version: DRV 10.6.1
Data as of: 20100902.
Address 01: Engine Control Module (038 906 019 KP)
21:48:37 Block 001: Quantity adjustment.
882 RPM (revolutions per minute) - Motor speed.
6.0 mg/H injection volume.
7.1°KW Actuation time for solenoid valve.
72.9°C Coolant temperature.
21:48:37 Block 002: Engine idling.
903 RPM (revolutions per minute) - Motor speed.
0.0% accelerator pedal position.
0 1 0 Operating status
21:48:37 Block 013: Engine idle control (fuel injection deviation).
-1.11 mg/H, Cylinder 1.
-0.33 mg/H, Cylinder 2.
-0.75 mg/H, Cylinder 3.
2.16 mg/H, Cylinder 4.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
21:49:39 Block 001: Quantity adjustment.
5.8 mg/H injection volume.
6.6 kW, Solenoid valve activation time.
74.7°C Coolant temperature.
21:49:39 Block 002: Engine idling.
21:49:39 Block 023: Switching time deviation (BIP).
-5.0 Cylinder 1
-33.0 Cylinder 2
-22.0 Cylinder 3
-66.0 Cylinder 4
21:49:42 Block 001: Quantity adjustment.
6.1°KW Actuation time for solenoid valve.
21:49:42 Block 002: Engine idling.
21:49:42 Block 023: Switching time deviation (BIP).
-5.0 Cylinder 1
-34.0 Cylinder 2
-23.0 Cylinder 3
-63.0 Cylinder 4
21:49:44 Block 001: Quantity adjustment.
21:49:44 Block 002: Engine idling.
21:49:44 Block 023: Switching time deviation (BIP).
0.0 Cylinder 1
-32.0 Cylinder 2
-22.0 Cylinder 3
-64.0 Cylinder 4
21:51:12 Block 001: Quantity adjustment.
76.5°C Coolant temperature.
21:51:12 Block 002: Engine idling.
21:51:12 Block 007: Temperature sensor.
60.3°C Fuel temperature (G81)
0.0% Status: Fuel Cooling.
32.4°C Intake air temperature (G42)
76.5°C Coolant temperature (G62)
Saturday, September 25, 2010, 9:52:34 PM: 26062
21:52:28
72.9°C Coolant temperature (G62)
Saturday, September 25, 2010, 9:43:07 PM: 26062
21:42:59 Block 001: Quantity adjustment.
0 /min Motor speed.
0.0 mg/H Injection volume.
-35.7°KW, Solenoid valve activation time.
69.3°C Coolant temperature.
21:42:59 Block 002: Engine idling.
0 /min Motor speed.
21:42:59 Block 007: Temperature sensor.
50.4°C Fuel temperature (G81)
27.9°C Intake air temperature (G42)
69.3°C Coolant temperature (G62)
Translated on 18-07-2026, 1:30.
juster321
Post26-09-2010, 10:02    Subject: VW Golf TDI starts, then dies Quote
This morning, it wouldn't start again. I checked all the temperature sensors I have, and they all showed the same value. I'm starting to get desperate.
Translated on 18-07-2026, 1:46.
Post26-09-2010, 15:57    Subject: VW Golf TDI starts, then dies Quote
Does it make a "gurgling" sound when you turn on the ignition? Is the electric fuel pump connected to the diesel filter working properly?
Translated on 18-07-2026, 1:47.
juster321
Post26-09-2010, 16:19    Subject: VW Golf TDI starts, then dies Quote
Yes, the pump is working without any problems.
Post26-09-2010, 16:56    Subject: VW Golf TDI starts, then dies Quote
juster321 wrote:
yes the pump is working without problems
Does it only make sounds, or does it actually deliver fuel?
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI starts and then immediately shuts down.... Diesel Engine Technology
No new posts VW Golf III TDI: Engine Problems & No Start? Diesel Engine Technology
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
No new posts Seat Ibiza ASZ TDI: Starts, then dies Diesel Engine Technology
