Engine Scan Error (AMV): Label address: none - now yes
derkater
Post05-07-2008, 0:39    Subject: Engine Scan Error (AMV): Label address: none - now yes Quote
Hello everyone,
I'm a complete beginner, so I'm going to start with a question that I haven't been able to find an answer to:
During the scan, no label files are specified/found for the MSG and climate control units, while label files are specified for the other six existing control units.
Can this be completed somehow, and is my hope justified that the environmental conditions will then be displayed to me during the MSG?
Vehicle is a T4 V6 (AMV), Part number: 022 906 032 C
I am grateful for the support.
Best regards, Stephan
Post05-07-2008, 20:54    Subject: Re: Engine Scan (AMV): Label address: none Quote
Hi Stephan,
derkater wrote:
Hello everyone,
Whether environmental conditions can be displayed in the error codes depends on the specific control device, not on the label files.
Maybe you mean the 'usual ranges' for the measurement blocks instead.
Since the VAG part number in your STG is already present in the corresponding label redirection, I assume that the corresponding file will follow at some point.
Best regards, Rainer
derkater
Post05-07-2008, 22:53    Subject: Engine Scan Error (AMV): Label address: none - now yes Quote
Hi Rainer,
thanks first.
I had been hoping to get information about the driving condition when the error occurred. This could potentially provide an indication of the cause. If not, then it's a shame. Typical ranges are likely something else icon_question.gif
Other information regarding MSG, such as part number, code, and operating number, is also listed elsewhere. This applies to the air conditioning unit as well. Now, given that the model has been on the market for six years, a malfunction is more likely than the possibility that the label files are unavailable.
I'm just curious, how does displaying the label files actually provide any benefit? Sorry, but I'm just not seeing it clearly.
Post06-07-2008, 9:31    Subject: Engine Scan Error (AMV): Label address: none - now yes Quote
I'm just curious, how do you see the advantage of displaying the label files? Sorry, but I'm just not able to see clearly.
In some display values in measurement blocks, VAG-COM/VCDS needs to determine the meaning, which is what is meant by that.
An example is the fill level of a diesel particulate filter.
The engine control unit here only provides, for example, 8%, but it doesn't specify what the 8% refers to. This could be a flow rate, a load, or simply the filter's fill level.
With the label file, VCDS can then state that the filter's fill level is 8%, otherwise it simply displays "8%" without any further information.
Furthermore, various information is included in the label files, such as permissible encoding variants or adjustment ranges.
derkater
Post06-07-2008, 13:50    Subject: Engine Scan Error (AMV): Label address: none - now yes Quote
I have found label files on Rosstech, including one named "redirect", which likely enables the use of the AMV machine.
022-906-032-AXK.LBL
02-01.LBL
I have correctly placed them in the "Users" labels, but the label file is not being displayed during the scan. What am I doing wrong?
vagtuning
Post06-07-2008, 16:01    Subject: Engine Scan Error (AMV): Label address: none - now yes Quote
02-01.lbl includes...
;022-906-032-C ; AMV: (7D)
...therefore, no label file exists and nothing appears to be there, as can be seen on the following page...
http://wiki.ross-tech.com/index.php/Control_Module_Maps
...is to create a representation for advertisements such as 'Label file: None' or 'Forwarding failed'.
derkater
Post06-07-2008, 16:22    Subject: Engine Scan Error (AMV): Label address: none - now yes Quote
...is to create an image when the status is "Label file: None" or "Forwarding failed".
Understanding Question:
Are these files unusable?
http://www.ross-tech.com/vag-com/download/label-files/022-906-032-AXK.lbl
http://www.ross-tech.com/vag-com/download/label-files/02-01.lbl
Am I completely off track? Please excuse me, but if so, then an explanation might help me.
vagtuning
Post06-07-2008, 16:35    Subject: Engine Scan Error (AMV): Label address: none - now yes Quote
As for how you see it, the AMV hasn't been captured yet.
So, I'm sending out the template now, and then there will definitely be one soon.
Whether the AMV could be identical to any other, one would have to without
can't see well.
The AKX is a US model, and the AYL is only available in the Sharan.
not on the bus....
derkater
Post06-07-2008, 20:45    Subject: Engine Scan Error (AMV): Label address: none - now yes Quote
vagtuning wrote:
However, the AMV is still not fully captured in your perspective.
I understood that it was already processed because it was a redirect-.lbl file. However, I diligently made the maps and attached the scan and sent it. Let's see what happens.
can't see well.
not on the bus....
That with the AKX was, surprisingly, something I knew - is the Eurovan
derkater
Post20-09-2010, 17:15    Subject: Finally! - Label file for AMV V6 Quote
Following the "better late than never" approach, we are now finally able to provide the label file for the MSG of the T4 V6. This needs to be said to wrap up this thread. icon_smile.gif is included in the current 10-update.
Greetings
Stephan
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 10-cent tuning, but no performance gain? Diesel Engine Technology
No new posts jetzt hat er gar keine Leistung mehr Diesel Engine Technology
No new posts First, no power, and now preheating, but it won't start Diesel Engine Technology
No new posts Wastegate: AFB or VTG? Diesel Engine Technology
