Audi A4: Sudden Power Loss (Pierburg MAF Sensor)
thom
Post29-03-2011, 10:51    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
Hello everyone,
"Yesterday, something strange happened to me. After overtaking a car, I suddenly lost all power. The engine was still running, but it didn't go into limp mode. It just didn't have any power. I initially thought it might be related to the VTG (Variable Turbine Geometry) and its adjustment, as I had recently replaced the hose to the vacuum actuator because it was worn. I then drove home like that. When I got home, I restarted the engine briefly, and to my surprise, everything was back to normal. This morning, I read the error codes."
16485 Air mass meter G70, implausible signal, error code P0101, -35-10---, interrupted.
17958 Boost pressure control differential p1550-35-00.
After that, I cleaned the mass airflow sensor and took it for a test drive. Still no power. I observed the boost pressure during the drive (using VAG-COM). Well, if you give it short bursts of acceleration, it does go up to 1 bar, but when driving normally, it only reaches 0.4 bar at 2500 RPM.
After that, I cleared the error codes and restarted the engine.
Unfortunately, the error persists.
17552 Air mass sensor G70: Disconnection/short circuit to ground detected.
I checked the connector, and I didn't see any broken wires.
I have to mention that the mass airflow sensor (MAF) doesn't seem to be original. It was replaced by the previous owner. I believe it should be a Bosch part, but I have a Pierburg one installed.
However, I drove 80,000 km with the Pierburg unit and only had to clean it once.
Can I check if the LMM is still producing reasonable values before I consider buying a new one?
Thomas.
Translated on 21-09-2026, 5:37.
Back to top Profile PM Email
Post29-03-2011, 11:26    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
/viewtopic.php?t=20765&highlight=pin assignment+MAF
Only measuring helps.
Translated on 21-09-2026, 5:40.
a4_afn
1997 Audi A4
Post29-03-2011, 14:39    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
"Since it already has a Pierburg mass airflow sensor, it should be fine as is."
thom
Post30-03-2011, 1:01    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
I logged data blocks 08 and 11 today.
Unfortunately, I was unable to create a visually appealing diagram.
Here's the translation:
"I also need to mention that the AGR (Abgasrückführung - exhaust gas recirculation) system is deactivated. After restarting the engine, and initially when starting to drive, nothing happens. However, if you fully depress the accelerator pedal in first gear, there's a surge at around 2500 RPM. I think that's when the VTG (variable turbine geometry) unlocks."
Mappe3.xls
 File name:  Mappe3.xls
 File size:  141 KB
 Downloaded:  476 times
LOG-01-011-008-010.CSV
 File name:  LOG-01-011-008-010.CSV
 File size:  5.14 KB
 Downloaded:  530 times
Translated on 21-09-2026, 5:41.
thom
Post30-03-2011, 23:37    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
Today, I sat down with my laptop next to the car again to see if it was really the mass airflow sensor.
I believe the LMM values are written to measurement block 3.
I think field 2 shows the target value, and field 3 shows the actual value.
In field 3, there's absolutely no activity; it's stuck at 550 mg/r, regardless of the speed.
That's why I'll also notice the increased fuel consumption, as I still have to drive the car every day.
And after 2200 revolutions, not much more happens.
Am I right in assuming that the mass airflow sensor (MAF) is defective?
Translated on 21-09-2026, 5:42.
thom
Post31-03-2011, 12:27    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
Today, I measured the pin configuration of the mass airflow sensor (MAF) with the engine off. Everything seemed okay, except that one pin, which should have had 5 volts, was showing slightly over 7 volts.
Is that something to be ignored?
Thomas.
Translated on 21-09-2026, 5:44.
Post31-03-2011, 12:29    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
Is that something to be disregarded??
No. It's likely a measurement error or a faulty wiring harness. The voltage regulator is less likely the cause, as that would also affect all other sensors, which would then receive 7V instead of 5V.
thom
Post02-04-2011, 7:21    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
Hello.
I installed a different LLM, and that was the problem.
As I found out from this forum, the Mercedes Sprinter now has a Bosch system again.
I actually have one more question: When the engine is idling, I'm getting a reading of 440 mg/h, which is quite a bit different from the target value (250 mg/h).
Is this still normal?
Thomas.
Translated on 21-09-2026, 5:45.
Klausel
Post02-04-2011, 20:41    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
Therefore.
What I still need to mention is that the EGR system is deactivated.
is it "normal"?
Best regards, Klaus.
Polo 6R, TSI 110 PS
Translated on 21-09-2026, 5:46.
thom
Post03-04-2011, 9:07    Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) Quote
Yes, that's right, I could have figured that out myself.
Thank you again to everyone who helped me.
Thomas.
Translated on 21-09-2026, 5:47.
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden total power loss on a 2.0 TDI Audi 8V Diesel Engine Technology
No new posts Plötzlicher Leistungsverlust T4 AHY On-Board Diagnostics (OBD)
No new posts Plötzlicher Leistungsverlust TDI Krankheit Diesel Engine Technology
No new posts Engine Failure While Driving: Causes & Fixes Diesel Engine Technology
