Jump Starter Issues: Troubleshooting & Solutions
Post16-03-2003, 22:30    Subject: Jump Starter Issues: Troubleshooting & Solutions Quote
Hello.
Based on the experiences of 98_ALH and my own, I wonder if the starter motor replacement, which has been described several times here as a solution, truly addresses the core of the problem, especially when it comes to warm start issues.
or whether the workshop "secretly" also installed new starter cables and that the transition resistances of the old, corroded cables were actually responsible for the starting problems, but the workshop couldn't resist the temptation to sell another starter motor as well.
If anyone reading this had starting problems that were resolved by replacing the starter, I would be interested to know (if it's still possible to determine):
- Were new cables installed between the battery and the starter, or between the battery and the engine block (ground cable)?
- Or were the connection points of the old cables noticeably clean/free of corrosion after the work was completed?
- Did the new starter motor have a different VAG or Bosch part number compared to the old one?
Translated on 17-09-2026, 16:08.
haehnlein
Post17-03-2003, 11:52    Subject: Jump Starter Issues: Troubleshooting & Solutions Quote
Hi Ulf,
"With my old TD, I had the problem that the starter motor didn't have enough speed, especially when the engine was warm (-> it would just make a 'orgel orgel' sound), and the magnetic switch was sticking. During a head gasket replacement, I fortunately got access to the connection point for the ground strap to the engine block. I simply used a grinder to clean the connections between the ground strap and the engine block, and the positive terminal and the starter motor (including the nuts, washers, and contact surfaces), and I lubricated the magnetic switch. After that, the starter motor worked perfectly again, like a icon_eek.gif."
____________
Kein Auto mehr!
Translated on 17-09-2026, 16:10.
Post18-03-2003, 17:52    Subject: Jump Starter Issues: Troubleshooting & Solutions Quote
haehnlein wrote:
I then simply used the angle grinder to remove the material from the connections between the ground wire and the motor, and the positive wire and the starter (including the nuts, washers, and contact surfaces), and I lubricated the magnetic switch. After that, the starter worked perfectly again. icon_eek.gif
Hi Christian,
So, it's also a "cable-instead-of-starter-motor" problem.
It seems to me that it's really coming from the starting quantity characteristic curve icon_sad.gif.
Translated on 17-09-2026, 16:11.
No new posts Fix Error 00777: Strange Effect? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motoraussetzer und Startprobleme beim TDI durch Biodiesel Diesel Engine Technology
No new posts Fix 00575? Everything OK? Upload
No new posts Leon Bj05 110kw - Kaum Bremsfunktion (vermutlich behoben ) Transmission, Chassis, Body & Interior
No new posts Problem behoben,neues Problem Diesel Engine Technology
