Log AFN with VP1L, various. MWBs
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
DieselBär30x
Avatar-DieselBär30x
Post13-11-2010, 3:52    Subject: Log AFN with VP1L, various. MWBs Quote
Edit1: New log entry 8/10/11 with MSG encoding changed from 00003 to 00001.
Edit2: Completely new logs under similar test conditions (same route, but with an outside temperature of approximately icon_smile_thumb_up.gif°C, almost no wind, road surface slightly damp but no rain) with a new dataset. All vehicles are driven with code 00001 (AG) except for KPower measurements, where code 00003 (All-wheel drive) is used alternately.
Edit3: Completely new logs under similar test conditions (same route, but with an outside temperature of approximately icon_smile_thumb_up.gif°C, moderate wind, wet road surface, and light rain). Everything was driven with encoding 00002 (SG), including. KPower measurement.
Uploaded a very noticeable MWB-13 log at -6°C (cold start).
Logs about fuel injection amounts, boost pressure, injection timing, etc.
The test track is relatively flat, with a speed limit of 60 km/h icon_wink.gif, but unfortunately, there is very strong wind, up to a storm, coming from the side.
Outdoor temperature: 14°C, air pressure (according to my ProTrek watch): 947 mbar, rain, the hairstyle is holding. icon_wink.gif
The vehicle was driven for over 30 kilometers on the highway under normal operating conditions.
The measurements were always taken in the same direction and under the same conditions; therefore, the respective logs can be compared directly.
Unless otherwise specified, the recording started, and then the vehicle was driven in aisles 1-4, starting at the lowest possible speed and gradually increasing to full throttle, reaching the highest possible speed in gear 4. Operating speed, or up to 4,000 RPM (where possible).
 Leistungs-Diagramm mit VP1L - diesmal mit Codierung 00002
 File size:  39.67 KB
 Viewed:  3538 times
 KPower Screen mit 2. Datensatz, Codierung auf SG (Allrad)
 File size:  39.5 KB
 Viewed:  1908 times
 KPower Screen mit 2. Datensatz, Codierung auf AG
 File size:  39.8 KB
 Viewed:  1936 times
 Leistungsdiagramm lt. KPower
 File size:  22.22 KB
 Viewed:  2687 times
 ScreenShot TDI-Timing-Checker über den Spritzbeginn an der Frühgrenze (DANKE @ GTI :) )
 File size:  60.67 KB
 Viewed:  2054 times
LOG-01-004-007-013.csv
 Kaltstart bei -6°C. Hier reißt der 1. MW des MWB13 gewaltig aus der Nominalen... Was ist das?!
Sonst sehr gute Starteigenschaften (nicht vorgeglüht nach ca. 2 sec. da!) und ruhiger LL.
 File name:  LOG-01-004-007-013.csv
 File size:  8.87 KB
 Downloaded:  791 times
LOG-01-014-xxx-xxx.csv
 Edit3: Neue Log-Datei mit fliegendem Start im 3. Gang Beschleunigung bis knapp Abregeldrehzahl (f. K-Power Leistungsmessung)
 File name:  LOG-01-014-xxx-xxx.csv
 File size:  8.66 KB
 Downloaded:  713 times
LOG-01-013-016-017.csv
 Edit3: Neue Log-Datei mit Leerlauf (LLRR). Marker 1: Alle el. Verbraucher AN. Marker 2: Alle el. Verbraucher AUS.
 File name:  LOG-01-013-016-017.csv
 File size:  10.63 KB
 Downloaded:  844 times
LOG-01-009-010-011.csv
 Edit3: Neue Log-Datei mit ca. 30 sec. Leerlauf, dann über Gänge 1-3 und 4 Beschleunigung bis knapp Abregeldrehzahl
 File name:  LOG-01-009-010-011.csv
 File size:  6.36 KB
 Downloaded:  711 times
LOG-01-008-010-011-2.csv
 Edit3: Beschleunigung 1,2,3,4. Gang bis 4.000 U/min
Ab 1.500 U/min wurde alle weitere 500 U/min Gaspedal für ca. 5 sec. auf 0% und dann wieder 100%. Regelschleifenprüfung
 File name:  LOG-01-008-010-011-2.csv
 File size:  7.86 KB
 Downloaded:  700 times
LOG-01-008-010-011-1.csv
Ab 1.500 U/min wurde alle weitere 500 U/min Gaspedal für ca. 1 sec. auf 0% und dann wieder 100%. Regelschleifenprüfung
 File name:  LOG-01-008-010-011-1.csv
 File size:  14.21 KB
 Downloaded:  771 times
LOG-01-008-010-011.csv
 Edit3: Beschleunigung 1,2,3,4. Gang bis 4.000 U/min. Regelschleifenprüfung
 File name:  LOG-01-008-010-011.csv
 File size:  10.1 KB
 Downloaded:  687 times
LOG-01-005-007-008.csv
 File name:  LOG-01-005-007-008.csv
 File size:  7.49 KB
 Downloaded:  703 times
LOG-01-001-003-004.csv
 File name:  LOG-01-001-003-004.csv
 File size:  9.06 KB
LOG-01-001-002-007.csv
 File name:  LOG-01-001-002-007.csv
 File size:  7.88 KB
LOG-01-001-002-004.csv
 File name:  LOG-01-001-002-004.csv
 File size:  8.13 KB
 Beschleunigung 4. Gang bis knapp Abregeldrehzahl (mit Anfahren über Gänge 1-3) mit 2. Software
 File size:  5.73 KB
 Downloaded:  738 times
 Nochmals wg. Umcodierung von 00003 auf 00001. Beschleunigung im 4. Gang bis knapp Abregeldrehzahl, dann kurz noch 5. Gang
 File size:  8.04 KB
 Downloaded:  692 times
LOG-03-001-002-xxx.csv
 Nebenbei: Gebrochener ABS-Zahnkranz auf Antriebswelle hi re führt zeitweise zum Regeleinsatz unter 30 km/h
 File name:  LOG-03-001-002-xxx.csv
 File size:  42.73 KB
 Downloaded:  767 times
LOG-01-008-010-011-4.csv
 Freie Beschleunigung ohne Motorlast sowie im 2. Gang jeweils bis Abregeldrehzahl. Letztere um ca. 200 U/min höher als früher. (gut geschmiert, gell? *g*)
 File name:  LOG-01-008-010-011-4.csv
 File size:  3.95 KB
 Downloaded:  760 times
LOG-01-008-010-011-3.csv
 File name:  LOG-01-008-010-011-3.csv
 File size:  6.69 KB
 Downloaded:  697 times
LOG-01-005-006-xxx.csv
 Beschleunigung NUR 3. Gang ab LL bis 4.700 U/min für KPower (s. folgender Screen)
 File name:  LOG-01-005-006-xxx.csv
 File size:  7.83 KB
Ab 1.500 U/min wurde alle weitere 500 U/min Gaspedal kurzmöglichst auf 0% und dann wieder 100%. Regelschleifenprüfung
 File size:  6.03 KB
 Downloaded:  719 times
 File size:  5.35 KB
 Downloaded:  718 times
 File size:  5.06 KB
 File size:  4.94 KB
 Downloaded:  809 times
LOG-01-019-020-022.CSV
 Leerlauf zur Kontrolle
 File name:  LOG-01-019-020-022.CSV
 File size:  5.34 KB
 Downloaded:  709 times
LOG-01-013-016-017.CSV
 Leerlauf zur Kontrolle:
LLRR ohne Last, ab Marke1 alle el. Verbraucher u. Klima an (s. Generator-Last), Marke2 alle wieder aus.
 File name:  LOG-01-013-016-017.CSV
 File size:  6.29 KB
 Downloaded:  732 times
LOG-01-009-010-011.CSV
 File name:  LOG-01-009-010-011.CSV
 File size:  1 KB
 Downloaded:  710 times
LOG-01-005-007-008.CSV
 File name:  LOG-01-005-007-008.CSV
 File size:  966 Bytes
 Downloaded:  714 times
LOG-01-001-003-004.CSV
 File name:  LOG-01-001-003-004.CSV
 File size:  1017 Bytes
 Downloaded:  671 times
