| Development of the 1.9 l TDI Engine | ||||||||||||||
| Herbert |
Here's an older article from the "Motortechnische Zeitschrift" that very interestingly describes the development steps leading to the 1.9-liter TDI engine with VP:
For example, it describes (so that the search function can find - Construction data 1.9 TDI, - Engine Management EDC, Engine Control Unit; - Spritz start control, with charge pressure control and height adjustment; - Combustion chamber optimization, design of piston groove and swirler channel; - Interpretation of the crank housing, crank shaft, bevel gear mounting, vibration damper; - Explanation of the timing belt drive; - Emission characteristics. A topic frequently discussed in the forum is the loosely mounted KW (suspension strut) mounting (loosening of the KW central screw and the KW strut extending). In this article, you will find the reason for the chosen construction method - this way, the KW cap for the TDI engine has been made durable. Springer Automotive Media has kindly allowed us to publish this here in the forum. We would like to thank them again for this! hg Herbert
Golf 7 DDYA (+ Audi 80 Avant B4 1Z 475Tkm - habe ich vom ersten bis zum letzten Tag gerne gefahren) (+ Passat Variant 32B CY 400Tkm) Translated on 03-07-2026, 14:19. |
| Ratings - Development of the 1.9 l TDI Engine | |
Average rating: 4.67 - worst rating: 4 - best rating: 5 - number of ratings: 3 - View ratings |
You cannot post new topics in this forum. |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.098s
