Document Transporter 7D, vehicle braking unevenly (Solution)
Michael II
Post18-03-2003, 11:39    Subject: Document Transporter 7D, vehicle braking unevenly Quote
The vehicle brakes unevenly while driving at speeds up to 50 km/h without the brake pedal being pressed.
Cause:
Due to an insulation fault in the ABS wiring harness, the EDS (Electronic Differential Lock) system may be temporarily activated – only at speeds below 50 km/h and when the brake pedal is not depressed. The fault memory often indicates one of the front wheel speed sensors.
Solution:
Spare part.
Tschüss
Michael II
Ratings - Document Transporter 7D, vehicle braking unevenly
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Clutch Problems: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Documentary about Whistling Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP is activating on its own. Help! On-Board Diagnostics (OBD)
No new posts Does the Sharan brake automatically? Is the ESP system re... On-Board Diagnostics (OBD)
No new posts ESP Warning Light: Car Brakes in Turns? Transmission, Chassis, Body & Interior
No new posts Uneven brake wear Transmission, Chassis, Body & Interior
