PSA HDi 200 Engine: Reliable or Not?
pschaefer
Post17-12-2010, 21:05    Subject: PSA HDi 200 Engine: Reliable or Not? Quote
Hello!
As a long-time PD driver, I've unfortunately become quite familiar with VAG diesel engines, but I'm now considering switching brands (even though it means I won't be able to use my beloved VCDS anymore icon_sad.gif).
The object of desire is the "HDi 200" engine, with 204 horsepower, a displacement of 2179 cm³, a bore/stroke of 81x88, a rated power of 150 kW at 4000 rpm, and 440 Nm of torque at 1900 rpm.
Unfortunately, that information is no longer in the brochure. Does anyone know more about this unit and would like to share their, of course, highly subjective opinion? icon_wink.gif
Is this thing good for 300,000 km (assuming the "exterior" lasts that long, of course icon_twisted.gif)?
Thank you & Best regards.
Peter.
Translated on 25-10-2026, 2:26.
mullemaus
Post18-12-2010, 16:51    Subject: PSA HDi 200 Engine: Reliable or Not? Quote
I can report from people in my circle who own the 2.2-liter engine with 177 horsepower. icon_biggrin.gif It just keeps running and running... And 300,000 kilometers is no problem. icon_wink.gif
Translated on 25-10-2026, 2:27.
pschaefer
Post19-12-2010, 16:04    Subject: PSA HDi 200 Engine: Reliable or Not? Quote
Well, that's quite something. The 177 hp is probably the engine from the previous model.
"Does anyone know how the engine was technically modified to produce 204 horsepower? Despite extensive online searches, I can't find any information about the specific modifications used... The problem is that there are many 2.2L HDIs "out there" with different horsepower ratings."
Bi-turbo? Common Rail pressure? DPF with or without additive? So many questions...
Translated on 25-10-2026, 2:28.
pschaefer
Post19-12-2010, 16:15    Subject: PSA HDi 200 Engine: Reliable or Not? Quote
Aaah! "Googling in French" does the trick (Source):
A new HDi engine is introduced to the C5 range: this new generation of 2.2-liter engines makes progress in all areas: power, torque, quietness, fuel consumption, and CO2 emissions. The recipes applied for its development are in line with those already used on other families of diesel engines in the range (4-cylinder 1.6 and 2.0-liter engines and 3.0-liter V6 engines). They mainly focus on the common rail system, now of the 3rd generation, with a maximum injection pressure increased to 2,000 bar, the combustion chambers which retain their specific ECCS (Extreme Conventional Combustion System) technology, and the reduction of the compression ratio (16 to 1) to benefit the reduction of noise levels and pollutant emissions.
The engine is powered by 2 turbochargers, whose sequential parallel arrangement allows for high torque output even at low engine speeds. Equipped in this way, the CITROËN C5 HDi 200 FAP develops 150 kW (204 hp CEE) at 3,500 rpm and a maximum torque of 450 Nm at 2,000 rpm. With a 6-speed automatic transmission, its performance is remarkable: 230 km/h (225 for the Tourer version), 8.3 seconds from 0 to 100 km/h (8.6), and a mixed cycle fuel consumption of 5.9 l/100 km (6.1). CO2 emissions are 155 g/km for the sedan and 159 g for the Tourer. Just like the CITROËN C5 HDi 240 FAP, this new version is distinguished externally by its chrome double exhaust pipe.
Okay, so we're talking about a CR 3rd generation engine with 2000 bar of pressure, a bi-turbo system, reduced compression, and two chrome exhaust pipes on the C5, just like the V6.
Translated on 25-10-2026, 2:31.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Off-Road Suspension: Is It Worth It? Transmission, Chassis, Body & Interior
No new posts Audi A6 C4: Best Aftermarket Mudguards/Fenders Transmission, Chassis, Body & Interior
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
