A4 2.5 TDI Interface: Best Options & Compatibility
exciter
Registered VCDS User
Post11-12-2010, 14:38    Subject: A4 2.5 TDI Interface: Best Options & Compatibility Quote
I recently acquired an Audi A4 B7, model year 2005, with a 2.5 TDI V6 engine, engine code BDG.
The vehicle recently received a new VP44 pump.
He has now driven 112,000 km. Unfortunately, the pump was mechanically damaged.
Now, when idling, it runs quite unevenly. There's a brief jerk/bump coming from the right cylinder bank (in the direction of travel) when I rev it up while stationary, and the RPM drops to around 1100.
Now I suspect that a nozzle might be malfunctioning.
I stopped by my friend's workshop at the Audi dealership today, and we quickly used VCDS to read the control unit data.
"There were no error codes. The boost pressure was 1 bar at idle, although the target value according to VCDS should be 795 mbar."
The idle speed control values were approximately as follows:
-1.33 mg/H, Cylinder 3.
-0.08 mg/H, Cylinder 1.
-0.39 mg/H, cylinder 6.
0.31 mg/H, cylinder 4.
-1.10 mg/H, cylinder 5.
We didn't find the second cylinder...
The intake air temperature was 21°C, while the outside temperature was 7°C.
Air mass: 192 mg/H at idle.
He hasn't really used the program very often, and I also didn't have any essential tools or resources at the time that were truly important.
We quickly wrote a short log entry... can you already see anything from it?
Now, I wanted to buy an interface that would allow me to read the car's data using VCDS.
Which one is the best option for me?
I look forward to hearing from you.
Sincerely,
Steffen.
LOG-01-013-012-014.csv
 Leerlaufregelwerte, VCDS Logdatei
 File name:  LOG-01-013-012-014.csv
 File size:  1.64 KB
 Downloaded:  581 times
Translated on 28-10-2026, 15:19.
exciter
Post12-12-2010, 20:24    Subject: A4 2.5 TDI Interface: Best Options & Compatibility Quote
No idea?
Does the standard interface cost 159 euros to diagnose the engine?
"Mine already has some CAN bus functionality, right?"
Translated on 28-10-2026, 15:22.
Post12-12-2010, 21:47    Subject: A4 2.5 TDI Interface: Best Options & Compatibility Quote
http://shop.dieselschrauber.de/VCDS-Fahrzeugliste.pdf
Nope, HEX-USB+CAN = Professional system:
http://shop.dieselschrauber.de/product_info.php/products_id/46
The cylinder heads on this engine have problematic valve mechanisms; it would be best to remove the cylinder head covers and take a look.
exciter
Post13-12-2010, 9:02    Subject: A4 2.5 TDI Interface: Best Options & Compatibility Quote
Okay, you're welcome.
Can a faulty nozzle cause something like that?
There's nothing to hear when it revs up.
Okay, I'll increase the speed quickly and then immediately reduce it again. Occasionally, I hear a dull noise or thud coming from the right side (passenger side) of the engine, but it doesn't happen all the time.
I believe the needle lifter is located there.
Best regards, Steffen.
Translated on 28-10-2026, 15:23.
Post13-12-2010, 9:40    Subject: A4 2.5 TDI Interface: Best Options & Compatibility Quote
More like not quite what you described...
Translated on 28-10-2026, 15:24.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts What interface is required On-Board Diagnostics (OBD)
No new posts Deals: Top 3 Products for 2005 On-Board Diagnostics (OBD)
No new posts Altea 2.0 FSI: Specs & Info for 2005 Model Gasoline Engine Technology
No new posts Deals: Top 1/3 Products for 2005 On-Board Diagnostics (OBD)
