Lima is not loading
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
chriskross
Post04-07-2011, 21:14    Subject: Lima is not loading Quote
Hello!
I'm having a problem with a Merc. W202 c250 turbo diesel.
The limakontroll lamp was lit in the cockpit.
So, the Lima (alternator) was replaced, but now I have a problem: the charging indicator light doesn't illuminate when the ignition is turned on.
The Lima charger is also not receiving a charge at the B+ terminal; it's only showing 12V.
I only have two connections on the Lima: B+ and D+.
When I connect the positive terminal (D+) and the negative terminal, I have battery voltage.
When the motor is running, I measure approximately 2.8V at terminal D+.
Can someone tell me what the normal voltage should be on the D+ terminal when the engine is running?
A6 AFB
A6 BRE DPF
DieselBär30x
Avatar-DieselBär30x
Post05-07-2011, 0:02    Subject: Lima is not loading Quote
Hello!
Where do you measure the battery voltage when the D+ line is disconnected? Should it be connected to the main cable or to the alternator?
Disconnect the D+ sensor again and check the following, both with the ignition ON and the engine idling:
- Connect the D+ wire to ground -> The charging indicator light must illuminate!
- Open circuit in the positive (+) line -> The charging indicator light should not be illuminated!
- Open D+ line (positive voltage) in the air -> voltage measurement of 12V or 14V when charging.
- Open D+ connection in the air -> Start the engine, briefly increase the RPM slightly above approximately 3,000 RPM, and then the on-board voltage should be significantly above 12V (around 14V) in the subsequent idle state.
The voltage at the connected D+ terminal should be less than 1V when the ignition is ON, and approximately equal to the B+ voltage when the engine is idling.
Is the replacement alternator new, and does it really fit the vehicle 100%? Possibly, the "new" used item is defective again.
Is the terminal on the alternator also marked with "D+" and not with "DF" or "W"?
Does the ignition coil have voltage at the housing, both when the ignition is ON and when the engine is idling? Measure!
Best regards from Munich!
chriskross
Post05-07-2011, 13:03    Subject: Lima is not loading Quote
I've now replaced the alternator again with a different one, and everything is okay now.
I had connected a D+ wire and was getting 8V when the ignition was on, but the engine was not running.
A6 AFB
A6 BRE DPF
No new posts DPF not regenerating Troubleshooting & Guides
No new posts 2.7l V6 CR-TDI, Anpassungskanäle funktionieren nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Schwache Leistung==> nicht LLM! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Why doesn't it want to be externally audited? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Lima lädt nicht - Drehzahlmesser steht , Öldrucklampe b... Diesel Engine Technology
No new posts AFN Alternator: Connect Terminal W to 120A Diesel Engine Technology
No new posts Audi A3: Which alternator fits? Diesel Engine Technology
