AGR Target vs. Actual: Differences Explained
bdsf2003
Post27-01-2011, 12:58    Subject: AGR Target vs. Actual: Differences Explained Quote
Hello everyone!
'Today, I used VAG COM to display the target and actual values. At idle, they match. When at full throttle, the target value increases significantly, but the actual value curve only reaches about 2/3 of the maximum upward range. Is this normal, and is it due to the short throttle bursts at idle, or is the EGR valve leaking? How would a leaking EGR valve manifest itself during driving? Thanks in advance for your tips!'
Björn.
Engine: 2.5 V6 TDI, 180 horsepower.
Translated on 07-09-2026, 16:55.
Post27-01-2011, 14:14    Subject: AGR Target vs. Actual: Differences Explained Quote
Please provide only the translation, no explanations.
"Please provide only hard numbers, for example, a clean log."
The V6 engine is unfortunately known for issues like breathing problems and camshaft failures.
Translated on 07-09-2026, 16:56.
Post27-01-2011, 15:48    Subject: AGR Target vs. Actual: Differences Explained Quote
...and please add the VAG-COM / VCDS serial number / license information to the user profile. icon_idea.gif
bdsf2003
Post28-01-2011, 11:55    Subject: AGR Target vs. Actual: Differences Explained Quote
I can't provide any specific numbers, log files, or any kind of identification numbers. I went to my trusted mechanic and played around with his laptop – mostly just to read the error codes.
Then I came across the mentioned function and displayed the 'graph' for the EGR target (red) and actual (green) values, and I accelerated a few times. As I wrote before, I noticed that the red curve (target value) is higher than the green curve (actual value). I just wanted to know if that's normal...
The car drives great and has good performance. The camshafts are not an issue since it's a 2004 model and the engine code starts with 'B'. I seem to have a trouble-free V6 TDI engine, and I love this engine – both the 2.5-liter version in my A6 and the 3.0-liter version in my Touareg.
I also can't imagine that worn-out valve springs would manifest as a low actual EGR value, because that would more likely result in a lack of power at higher RPMs, as the amount of air being drawn in, and therefore the amount of fuel being injected, would be too low due to the valves not opening fully?
'No offense, the car is running great, and I'm not getting worked up about it. It's probably normal that, during brief bursts of full throttle at idle, the EGR valve doesn't quite reach its target closing position.'
Greetings.
Björn.
Translated on 07-09-2026, 16:58.
No new posts P0011 - Camshaft Timing Delayed: Not Reached Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Curve: Troubleshooting Turbocharger Issues on VW T4 AHY On-Board Diagnostics (OBD)
No new posts ESP Connectors: 8-Pin vs. 10-Pin Diesel Engine Technology
No new posts AGR Value Too High: Troubleshooting Guide Diesel Engine Technology
No new posts BMP air mass value too high? Diesel Engine Technology
