Immobilizer: Engine Control Unit (ECU) Not Learning
Post08-02-2011, 10:17    Subject: Immobilizer: Engine Control Unit (ECU) Not Learning Quote
Good morning.
Here's the translation:
"This is about the following vehicle:"
Ford Galaxy, engine code AHU, TDI diesel, registration letter "AHU", manufactured in 1998.
The old MSG has a fault in the altitude sensor (which cannot be fixed by replacing it or using a voltage divider) and needs to be replaced. I obtained one from a Galaxy manufactured in 1996, and I want to adapt it to my 1551 for use with the WFS:
Address: 25
Function 10.
Channel 00: Delete learning values --> Yes.
Function 06: Exit and turn off the ignition.
The vehicle starts briefly but immediately shuts off again, even after repeated attempts.
If I reinstall the defective MSG (Modular Service Interface), it will also be locked. However, this procedure of pairing the WFS (Wireless Front System) works perfectly there; the engine starts and stays running.
I tried to delete the learning values in the MSG, but when I confirm it, I get the message: "Function not possible..."
Where could the problem be?
Thank you for your help.
Ruedi.
Translated on 29-07-2026, 4:35.
Post08-02-2011, 11:24    Subject: Immobilizer: Engine Control Unit (ECU) Not Learning Quote
Is the part number of the "new" engine control unit (ECU) identical to the old one?
Translated on 29-07-2026, 4:37.
Post08-02-2011, 12:52    Subject: Immobilizer: Engine Control Unit (ECU) Not Learning Quote
Hi.
It has a different index; instead of "HC" like the old one, it uses "P".
"I took this out of a wrecked 1996 Galaxy with an AHU engine, which the scrap dealer said was still running. I can take it back if it doesn't fit, but unfortunately, he doesn't have any other options."
Best regards, Rüdi.
Post08-02-2011, 13:18    Subject: Immobilizer: Engine Control Unit (ECU) Not Learning Quote
Does the vehicle possibly still have WFS I installed?
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_I_ECU_Swapping
Rainer
Please add your VCDS license information to your profile!
Translated on 29-07-2026, 4:38.
Post08-02-2011, 13:22    Subject: Immobilizer: Engine Control Unit (ECU) Not Learning Quote
"How can I find out the version number? My English isn't very good."
I only know that the WFS control unit is a separate component located under the MSG (presumably an abbreviation for another part).
Would this number be helpful to them?
I cannot provide any data for Linz; I am currently using an older version from 1551.
Translated on 29-07-2026, 4:39.
Post08-02-2011, 13:56    Subject: Immobilizer: Engine Control Unit (ECU) Not Learning Quote
Do you have a PIN sticker on your keychain?
http://translate.google.de/translate?js=n&prev=_t&hl=de&ie=UTF-8&layout=2&eotf=1&sl=en&tl=de&u=http%3A%2F%2Fwiki.ross-tech.com%2Fwiki%2Findex.php%2FImmobilizer_I_ECU_Swapping
Translated on 29-07-2026, 4:40.
Post08-02-2011, 14:00    Subject: Immobilizer: Engine Control Unit (ECU) Not Learning Quote
We only bought the car two weeks ago, and it came with nothing but two keys; the previous owner didn't include anything else.
mullemaus
Post09-02-2011, 1:01    Subject: Immobilizer: Engine Control Unit (ECU) Not Learning Quote
How can I find out the version, my English is not very good.
I only know that the WFS control unit is a separate component located under the MSG (presumably referring to a specific module or system).
I cannot provide Linz data; I am working with an old version from 1551.
Yes, the number might be helpful if needed icon_wink.gif.
Translated on 29-07-2026, 4:41.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts A4 Doku: Engine Control Not Connecting to WFS. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.6 TDI AGR module cannot be programmed Diesel Engine Technology
No new posts A4 B5 New throttle body cannot be initialized Gasoline Engine Technology
No new posts Help, I can't adjust my immobilizer On-Board Diagnostics (OBD)
No new posts AFN Engine Control Unit: No Reprogramming On-Board Diagnostics (OBD)
