| Nach welcher Laufleistung trat bei Eurem TDI der erste Turboladerschaden auf? |
| weniger als 50.000km |
10% |
[ 9 ] |
| zwischen 50.000km und 100.000km |
18% |
[ 15 ] |
| zwischen 100.000km und 150.000km |
9% |
[ 8 ] |
| zwischen 150.000km und 200.000km |
15% |
[ 13 ] |
| zwischen 200.000km und 250.000km |
6% |
[ 5 ] |
| mehr als 250.000km |
39% |
[ 33 ] |
| Total votes : 83 |
donalexo Profi-Schrauber
Joined: 01/09/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
21-04-2004, 0:28 Subject: |
Hello everyone!
I am interested in the average expected lifespan of exhaust gas turbochargers that are subjected to very high thermal and mechanical loads in modern TDIs.
Therefore, I am starting a small survey here in the forum, where you can share your experiences.
Please only post if you have already had a turbocharger failure
Please support me generously so that the survey provides reasonably representative results. Thank you
If you don't mind, I would appreciate it if you could provide the MKB and, if known, the cause of the failure/defect.
In this context, information about the driving profile would also be helpful, for example, in the form:
xx% City, xx% Country Road, xx% Highway, Average Consumption x.x l/100km
Based on the driving distances and the average fuel consumption, I am able to form a good understanding of how the engine is performing.
Thank you for your posts
Hello
Alex AUDI A3 1.9 TDI, EZ 12/96, ursprüglich MKB AGR, umgebaut zum AHF mit GT1749V-Lader, verkauft mit 250tkm
Touran 1.9 TDI, EZ 09/2004
Julian Guest
21-04-2004, 7:39 Subject: |
1. 12/998 ALH: Mileage 72,000km. Engine damage. Reason: Too thin oil from the workshop was filled in (0W-40), the turbo forced oil into the engine, which burned in the exhaust system... => Defect.
2. 03/00 ALH: Ran well, over 160,000km.
Steffarn Profi-Schrauber
21-04-2004, 7:59 Subject: |
Motor AFN, 262tkm, still the first turbo!
Engine replaced at 252,000 km, due to engine damage caused by a broken timing belt  B.Eng (FH) u. KFZ Meister
Profile PM Email Garage |
21-04-2004, 9:00 Subject: |
Hi Alex,
So far, we have been spared from "real" TDIs, but we haven't driven them for very long yet.
My VTG at the AFN was sometimes experiencing more wear than the small membrane container, particularly around 20,000 km.
At VW, I would definitely have gotten a new supercharger - of course, the original part with the small can, etc. etc.
A larger container has also solved the problem, for a fraction of the cost
Whether you consider this to be a case of damage caused by the charging process, that is up to you. . .
Additionally, I suggest that you mark the thread as important (-> edit), which will keep it at the top until you mark it as normal again  Gruß Ulf
Profile PM Garage |
DocSnydor Guest
21-04-2004, 9:04 Subject: |
1Z, now over 250,000 km
50 % COMPLETE
35 % Road
15% of the city
Consumes 5-6 liters per 100 km
No harm has been caused so far.
(until the load-up phase is complete below 2500 RPM  )
AndreasG Guest
21-04-2004, 9:29 Subject: |
4/98 AHF, now with 145,000 km
70 % AB
20 % Road
10% of the city
Consumes 5.5-6.5 liters per 100 km
Turbocharger bearing failure at 80,000 km
Wurstblinker Guest
21-04-2004, 10:08 Subject: |
More than 300,000 km on the Audi 80 with no problems.
Recently, I've been driving a lot of short distances/city driving!
Greetings
leolotus Guest
21-04-2004, 10:25 Subject: |
> 170,000 km on the 110hp A3 (99 model year)
...and still ran without a complaint.
georg2 Guest
22-04-2004, 20:58 Subject: |
audi 80 avant 1 Z - 66 kw - original - AGR closed
192 tkm
runs like new with 1 turbo
consumption of 5.8 to 7 liters
georg aus ö.
Sir Tortsch Guest
22-04-2004, 23:13 Subject: |
Gofl 4 ALH, built in 1998, with over 190,000 km.
50 % COMPLETE
30 % Road
20% of the city
has worked until I sold it.
ttns4 Guest
23-04-2004, 12:42 Subject: |
PD AJM Passat, 123,000 KM, Turbocharger okay
Greetings
ttns4
Cabriodriver Guest
23-04-2004, 12:57 Subject: |
11/95 Audi 80 Cabrio B4
Mileage: 1Z with over 240,000 km
approximately 60% highway, 20% rural roads, 20% urban traffic.
ca. 6,0 l/100km Average fuel consumption
The turbocharger is the first one, and as far as I can tell, it's still 100% functional!
Olaf
Joined: 04/16/2002 Posts: 307 Karma: +0 / -0 Location: Bargteheide
23-04-2004, 22:03 Subject: |
Year: 2000, AMF (1.4 TDI), 30 ABx30 LAx40, City use, average consumption of approximately 5 L.
Chip failure at 22,000 km. Out of the approximately 15,000 km of country roads, only those sections on mountain passes were driven under full load.
The pump had pushed so much oil through the shaft at around 102,000 km that the engine switched to emergency mode.
Greetings
Olaf
Profile PM Email |
hvx Guest
24-04-2004, 0:01 Subject: |
Golf 3 AFN, 81 kw. Everything original. 192,000 km, no problems so far.
Consume 5.3 liters.
Manuel Thomas Guest
24-04-2004, 0:28 Subject: |
225,000 km AFN with Chiptuning. Then modified and stored in the basement for 'bad times'! I've installed the 130hp TDI turbo!
Greetings
Manuel
WarLord Guest
24-04-2004, 12:12 Subject: |
Passat 3B TDI ATJ 115 hp PD, 120,000 km, turbocharger ok.
Before: Passat 35i TDI 1Z, 174,000 km, turbocharger ok (had, I think, only a stuck wastegate, but otherwise ok)
