DPF: 2.7/3.0 TDI Diesel Particulate Filter
kiepski15
Post02-02-2011, 23:36    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
Hello everyone!
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
I once used VCDS to read the data from my particulate filter! Now it shows 0.12 for oil ash content.
Is that the ash content? When is the filter full of ash, or when does it need to be replaced? Does anyone happen to know?
Micha
Translated on 29-08-2026, 11:22.
Post03-02-2011, 8:31    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
Hi.
Please provide more information.
- Which engine (model code)?
- the precise measurement blocks.
It's very easy to do; just click "Save" within each section.
Translated on 29-08-2026, 11:24.
kiepski15
Post03-02-2011, 9:19    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
Yes, sorry!
I'll provide the data later.
The engine is a 2.7 TDI BPP!
Karma: +807 / -0   Thank you, like it!
Post03-02-2011, 16:32    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
The easiest way is to hover the mouse cursor over the corresponding field in the measurement blocks.
Please provide the VAG part number for the engine control unit. The corresponding label file (click on the blue-highlighted label file name) also explains how the value is calculated and what the valid ranges are.
Translated on 29-08-2026, 11:25.
Post03-02-2011, 20:24    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
I was looking for information on the ASB (Arbeitsstättenverordnung - Workplace Regulations), but block 104 doesn't mention anything about maximum values.
Translated on 29-08-2026, 11:26.
kiepski15
Post06-02-2011, 14:44    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
Here's the value for the filter! Unfortunately, unlike many data points, a value hasn't been assigned here.
Log-95383-rußfilter.txt
 File name:  Log-95383-rußfilter.txt
 File size:  600 Bytes
 Downloaded:  1456 times
Post06-02-2011, 15:09    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
I think your oil ash volume is displayed in liters. It's probably normal to see 0.25 liters at 150,000 km.
I haven't found a precise "threshold" at which a replacement is necessary. However, cleaning the DPF every 150,000 km (approximately 93,000 miles) can't hurt, as it can help reduce exhaust backpressure and, consequently, improve fuel consumption.
Translated on 29-08-2026, 11:27.
bloesch
Post06-02-2011, 16:12    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
If I remember correctly, according to the original specifications, the limit is 0.2 liters.
kiepski15
Post06-02-2011, 19:00    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
Ah ok 0.2-0.25 ist doch schonmal eine Hausnummer! "Thank you!"
What do you mean by "clean it at 150,000 km"?
Forced regeneration, or new? What do you think?
Translated on 29-08-2026, 11:28.
Post06-02-2011, 19:23    Subject: DPF: 2.7/3.0 TDI Diesel Particulate Filter Quote
Okay, I'm ready. Please provide the German text you want me to translate.
No new posts Particulate Filter (DPF) VAG TDI Diesel Mass Balance, Max... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Forced DPF Regeneration: VAG TDI with VCDS Troubleshooting & Guides
No new posts New particulate filter Diesel Engine Technology
No new posts Problems with the particulate filter Diesel Engine Technology
No new posts Particulate Filter Failure: Causes & Solutions Diesel Engine Technology
No new posts Particulate Filter: Additive-Free & Efficient Diesel Engine Technology
