Resolution: "Crack in BKD cylinder head" (Solution)
schlauchdruide
dieselschrauber and Herbert likes this.
Post14-12-2010, 12:06    Subject: Resolution: "Crack in BKD cylinder head" Quote
As you can see in the pictures, cylinder heads from 16V TDI engines can also crack in a way that causes the exhaust side to become completely flooded with water.
That's why the diagnosis with a removed intake manifold is not always correct. I hope this helps other mechanics with troubleshooting and that this potential issue is also taken into consideration.
 Aufbau zum Abdrücken des Zylinderkopf (BKD, 16V TDI)
 File name:  P1000633.JPG
 File size:  5.65 MB
 Downloaded:  5135 times
 2.Zylinder auslaßseitig undicht, Kühlmittelverlust im Zylinderkopf (BKD, 16V TDI)
 File name:  P1000631.JPG
 File size:  5.54 MB
 Downloaded:  4296 times
Ratings - Resolution: "Crack in BKD cylinder head"
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 2 - View ratings
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts "Self-activating" daytime running lights (6N, 1M, 1U, 1J) General Tips
No new posts Cracked Cylinder Head: Symptoms & Repair Diesel Engine Technology
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts "AdBlue error message, but fault memory is empty." Diesel Engine Technology
