When should I set the AGR?
Buggel
Post21-03-2003, 17:48    Subject: When should I set the AGR? Quote
Hello!
After reading many posts about the Agr shutdown,
I've come to the conclusion that I should also {ACTION}.
'to bring to a standstill'
The question is simply, 'From what date?'
My Seat Ibiza is only 4 weeks old and has already covered 2800 km.
It's the 100PS PD (ATD) engine.
Can the AGR be set within the warranty period without
that it can be proven?
When should you expect contamination in the intake system?
What negatively affects the engine?
I am very grateful for every piece of advice.
Bye!
Post21-03-2003, 17:58    Subject: Re: When to set the AGR? Quote
"to bring to a standstill"
The question is simply, "From what date?"
... completely irrelevant ... It is always illegal!
... it depends on how you approach it. I wouldn't guess.
... after the first start of the engine!
After I had disabled them due to the rough running issues, I'm now happy to be driving again (legally + under warranty).
No new posts Crankcase Ventilation: How to Disable/Deactivate Diesel Engine Technology
This topic is locked, you cannot edit or reply. AGR Valve: How to Deactivate/Disable? Diesel Engine Technology
This topic is locked, you cannot edit or reply. ASZ TDI Euro 3: AGR Valve Replacement & Deactivation Diesel Engine Technology
No new posts Oil Overfill: When Is It Harmful? Diesel Engine Technology
