Error Codes: What Do They Mean?
merlin
Post27-03-2003, 0:08    Subject: Error Codes: What Do They Mean? Quote
Hi everyone,
I recently used VAG-COM to read the diagnostic codes from my A4, and I found the following error codes. Can anyone tell me more about them?
Engine.
'One error found:'
00513 - Ignition timing sensor (G4)
03-00 - No signal.
Combination instrument.
'One error found:'
00779 - Sensor for vertical acceleration (G90).
30-00 - Interruption or short circuit after the positive terminal.
Best regards and many thanks.
Markus.
Translated on 01-11-2026, 6:32.
Michael II
Post27-03-2003, 7:54    Subject: Error Codes: What Do They Mean? Quote
Please also provide the model year and engine code.
Error code 779 in the instrument cluster does not refer to the G90 sensor, but rather to the G17 sensor (outside temperature sensor). Once again, VAG-Com has assigned the wrong text to the error code.
Tschüss
Michael II
Translated on 01-11-2026, 6:34.
merlin
Post27-03-2003, 8:25    Subject: Error Codes: What Do They Mean? Quote
A4 Avant B5 V6 TDI, manufactured in 2000. Engine code: AKN.
Michael II
Post27-03-2003, 9:11    Subject: Error Codes: What Do They Mean? Quote
Hello Merlin,
For the AKN (presumably a system or organization), there is an error table in the error/knowledge database.
Error code 779 in the combination instrument indicates either a wiring problem to the G17 module or a faulty G17 module.
Tschüss
Michael II
Translated on 01-11-2026, 6:35.
No new posts Error codes and their causes for MKB AJM, ATJ, AVF, AWX Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts ASV Error Codes: Troubleshooting & Solutions Diesel Engine Technology
No new posts VW T4 Error Codes: Troubleshooting Guide On-Board Diagnostics (OBD)
