BMP, 180 Tkm, 58 g ash, and now?
Post26-02-2011, 19:26    Subject: BMP, 180 Tkm, 58 g ash, and now? Quote
I just had a BMP on my line, with approximately 180,000 km on the odometer.
He has 58 g of ash in the filter.
What would happen if the user simply continues to operate it and ignores the 60g limit?
Karma: +792 / -0   Thank you, like it!
Post26-02-2011, 19:47    Subject: BMP, 180 Tkm, 58 g ash, and now? Quote
Does the engine get too hot (leading to wear and tear), regenerate unnecessarily often, and require an unnecessary amount of fuel?
Maybe, at some point, a fault notification will also appear in combination, which I haven't tried out yet.
Why not create a differential pressure log and verschandeln the filter? The duration of the action should be no more than 1 day, preferably less. Cost if nothing is broken: nothing, well, a few new nuts are sensible, seals are optional.
Hi, Rainer
Post27-02-2011, 10:59    Subject: BMP, 180 Tkm, 58 g ash, and now? Quote
It's not my BMP.
The user didn't know until yesterday that this part "can become full".
Initially, I thought it was a BKP (MJ 06 140 Horse), but when I wanted to take a look under the hood: Oops, not 16V... 179xxx km... oh no.
I've already told him about the possibility of washing it.
I need to review the DiffDruckLog again in order to detect successful rinsing.
He has two corks at home and is now gaining experience.
No new posts Asche und Russ bei DPF-Regeneration Diesel Engine Technology
No new posts Clean the DPF instead of replacing it Diesel Engine Technology
