15-11-2007, 7:43 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
I often get annoyed by the generally high prices of replacement parts, so I always buy headlight bulbs from the cheapest possible sources as generic ("no-name") parts (like Unitec, Alpine, etc.), for example, at hardware stores.
"Now it seems that our Ibiza 6K wears out these cheap bulbs a bit faster than the parts originally installed by the factory (my Polo still has the original bulbs)."
Does anyone here happen to know anything about the different qualities and artificially inflated lifespan ratings of branded versus generic light bulbs?
"I have occasionally read online (please don't ask me for links) that voltage spikes from the vehicle's electrical system can significantly reduce the lifespan of light bulbs. Therefore, poorly designed wiring harnesses could contribute to premature lamp failure."
If that's really true, I could build RF filters using materials from my electronics junk box so that the light bulbs would receive mostly "clean" power (with minimal voltage loss due to filtering).
Would that be a conceivable solution to extend the lifespan of the light bulbs?
Translated on 07-08-2026, 21:52.
Profile PM Garage |
Bertil Profi-Schrauber
15-11-2007, 8:08 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Hi Ulf,
My Golf had similar problems. I needed to replace the set of glow plugs every 5-6 months.
"In my case, it was clearly visible that the filament had broken rather than burned out. The reason for this is vibration. The plastic bracket in the front bumper of the Golf is particularly susceptible to this. After my accident and the replacement of the front bracket, the rate at which my headlights burn out has significantly decreased."
"When a light bulb burns out now, you can see that the filament has melted (i.e., burned through). This happens roughly every 15-18 months. I can live with that. At this age, the light bulbs are already noticeably dimmer, and it's probably a good idea to replace them anyway."
Your statement about voltage spikes is also correct. H7 bulbs are particularly sensitive to them. Unfortunately, the high light output also has its drawbacks. If a bulb fails due to voltage spikes, the filament should be visibly burned out.
What do your "used" light bulbs look like?
Translated on 07-08-2026, 21:55.
15-11-2007, 8:35 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Bertil wrote: | | What do your "used up" light bulbs look like? | Hi Bertil,
I have two broken light bulbs from this IKEA lamp.
Both glass bulbs appear completely transparent; there is no visible metallic vapor deposit, which was often the case with "finished" (non-halogen) light bulbs in the past.
The remaining filament pieces are still intact and of full length, well-formed, and in my opinion, they look more like they were cut off rather than melted.
However, when viewed under a microscope, the ends of the spirals sometimes show small, spherical shapes that appear to be partially melted.
"In my opinion, this could be caused by localized overheating in the area of an incipient vibration fracture: just before failure, the available conductor cross-section decreases -> the resistance increases locally, and according to P = I² x R, the temperature could rise above the melting point of the heating element."
What do H7 bulbs that are typically overloaded due to being used in an all-electric system look like?
Translated on 07-08-2026, 21:58.
Profile PM Garage |
15-11-2007, 8:59 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
ulf wrote: | ...
That sounds more like "broken" or "damaged." The lamps likely failed due to vibrations.
Based on how you describe the ends, I also assume that's the case.
Quote: |
What do H7 bulbs that are typically overloaded with electricity look like? |
Then, the remnants of burnt filaments are inside the glass bulb, often even completely fused together.
What type of front carrier does the Ibiza have? Is it made of plastic or metal?
My brother's Skoda had a metal front crossmember, and he experienced significantly fewer problems with the headlights compared to me in my Golf.
Translated on 07-08-2026, 22:00.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
15-11-2007, 10:50 Subject: H7 Bulbs: Reduce Wear & Increase Lifespan |
ulf wrote: | Hello,
Does anyone here happen to know any background information about the different qualities and artificially inserted burn times of branded versus generic light bulbs? |
I'm also not familiar with the burn times, but in almost all tests, these generic brands showed significantly higher manufacturing tolerances. This manifested itself in unacceptably high glare values, and mechanically, the fins were sometimes installed at such skewed angles that, in my opinion, proper heat dissipation was impossible, as was the designed strength against vibrations. Once again, "you get what you pay for" applies here.
My recommendation for good durability with headlight designs that are compatible with oncoming traffic is to choose premium lamps from reputable brands like Osram or Philips. These consistently demonstrate very good light output while maintaining maximum lifespan. While the common "+30%" or "+50%" lamps improve light output, they also tend to reduce their service life somewhat. According to the manufacturers, the higher light output in these cases is partly due to a more precisely manufactured filament.
Osram Night @ Day lamps, designed for continuous headlights, offer a longer lifespan but have slightly lower light output compared to standard lamps.
Currently, I'm using Osram Silverstar bulbs as H7 replacements, which provide significantly more light on the road compared to the standard ones. In the past 2.5 years, I've only experienced one failure.
Quote: | | 2. I have occasionally read (please don't ask me for links) on the internet that voltage spikes from the vehicle's electrical system can significantly reduce the lifespan of the bulbs. Therefore, poorly designed wiring harnesses would contribute to premature lamp failure. |
I would place this in the realm of esotericism, because whatever form these "peaks" take, they must carry a significant amount of energy to have any noticeable effect. The light bulbs, as powerful consumers, would need to reliably short-circuit such interactions so that they cannot become effective from an energetic perspective.
As classic cold solder joints, the lamps are particularly vulnerable when switched on, especially if the alternator attempts to quickly recharge the battery after a cold start and completion of the preheating process by increasing the voltage. Also common are bumpy roads, sports suspensions, and accidentally leaving the hood open with the lights on.
However, a high-quality brand lamp handles this situation somewhat better and still costs only slightly more than the cheap, low-quality products. You just shouldn't buy it from an authorized dealer.
Here you can see a hot break and a cold break (both from my H7 production line).
Translated on 07-08-2026, 22:05.
Profile PM Garage |
Thomas K. Guest
15-11-2007, 12:15 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Hello Ulf,
In your Polo, as with other VW models, the so-called body control module (BCM) was introduced. Its main function is to control the exterior lighting using power transistors, rather than directly switching voltage via the light switch or relays.
I only know for the Audi A4 (B6/7) that the voltage at the lamps is a maximum of 12.8 V. If the on-board voltage is higher, the lamps are dimmed using PWM (Pulse Width Modulation). This also applies to DC systems. I believe it's the same for Polo and Golf as well.
At Volkswagen/Audi, so-called 'LongLife' bulbs are used, which are designed for maximum lifespan.
Normally, the lamps should last significantly longer than they used to, provided they are not damaged.
Translated on 07-08-2026, 22:10.
15-11-2007, 12:25 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Bertil wrote: | Quote: | | What do H7 bulbs typically look like when they are overloaded due to being used with an all-electric system? |
Then, the remnants of burnt filaments are inside the glass bulb. | In most cases, they are even completely melted together. Quote: | Therefore, these seem very different from broken Ibiza bulbs.
| What type of front crossmember does the Ibiza have? Plastic or metal?:?Oh dear, that's a good question... I've never removed the front bumper before. But the upper locking rail "crossbar" is definitely made of sheet metal.
In the Polo, the corresponding area looks like plastic, but the "front fascia" (which houses the radiator and provides mounting points for front spoilers and lights) is at least partially made of a composite material: plastic on the outside, with metal profiles inside. This inevitably becomes an issue when trying to create space for the Ibiza Cupra FMIC (Front Mount Intercooler).
Another idea:
If vibrations are damaging the bulbs, one should be able to mitigate this with "dampening" masses, for example, by attaching lead strips to the outside of the roof rack above the reflectors, or even self-adhesive anti-vibration mats – provided that the material and adhesive can withstand the temperatures  .
@ Roger :
Regarding the electrical system, I had exactly the same thoughts as you about the energy content of disturbances in the vehicle's power network.
Great photos, by the way Thomas K wrote: | .
Interestingly, the broken Ibiza pears also show small melted beads, just like in your lower picture – but precisely at the ends of the spirals, rather than a bit before the end.
My guess is as follows (see above).
| In your Polo, VW started using what's called the onboard network control unit (BCU). Its main function is to control the exterior lighting via power transistors, rather than directly switching voltage through the light switch or relays. } No, in the 9N, the BCU doesn't have anything to do with the headlights: According to the wiring diagram, the current flows, as is typical for VAG vehicles, from the X contact of the ignition switch and directly to the bulbs via the light switch.
Translated on 07-08-2026, 22:14.
Profile PM Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
15-11-2007, 12:40 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
"Nowadays, there are also long-life H7 bulbs available from various budget brands. The light color is noticeably more yellow, and they didn't even match the brightness of the original H7 bulbs (Philips Premium) in my Peugeot 206. However, the standard H7 bulbs in my 206, which I bought as a nearly new car (9 months old), also stopped working less than a week after I purchased it. The car was probably driven with its lights on for every kilometer of its previous mileage when it was used as a demonstration vehicle. After that, I quickly removed the long-life bulbs ("AIA") that I bought because the illumination was too weak, and especially lacked brightness in the side lighting."
However, the geometry of the lamps in cheaper products is often unsatisfactory. They either turn out to be poorly designed or don't provide enough illumination. For example, the Chinese AIA lamps, which are offered at a relatively low price, are often candidates that exhibit both of these problems.
Brightness-enhanced H7 bulbs can be identified by their relatively compact filament, which is also made of what appears to be very thin wire. The cheaper ones usually have a noticeably thicker filament that is also longer in terms of dimensions. When measuring their power consumption using a stabilized 13.8 V power supply, they often draw more power than the standard bulbs. Based on calculations, I consistently measured at least 60 W for H7 bulbs with the thicker filament, and most were close to 65 W. However, since the brightness was noticeably lower compared to the Philips Premium bulbs, more of the electricity must be converted into heat.  On the other hand, the thicker filament is likely less susceptible to damage from voltage spikes.
Looking at the manufacturer's website, for example Philips, H7 bulbs are typically rated for around 300 operating hours. For someone who commutes with one hour of driving each way and perhaps makes a few private trips, a "always-on" driver would likely get about three quarters of a year out of them. This aligns with our observations!
Good maintenance is likely to extend the lifespan of components! Therefore, it's essential to avoid letting the hood slam shut while the interior light is on. The same applies to the license plate lights if the license plate is located in the tailgate. I recommend replacing W5W (5 watt) bulbs with, for example, W3W (3 watt) bulbs. It's also important to ensure that the lamps have a central support for the filament, as this makes them less susceptible to vibrations. The W3W bulbs are only slightly darker than the W5W bulbs, and the latter don't stay bright for very long after being new. The interesting thing is that you don't pay more for bulbs with a central filament support or for the 3 watt version compared to standard Philips or Osram bulbs without these features, and those standard bulbs in my cars haven't lasted particularly long anyway.
Currently, I am very satisfied with the Philips H7 All Weather bulbs that I managed to buy at a reasonable price. There's nothing better for the fog lights (which use H1 bulbs in my 206), and I've always liked using them for the low beam as well! They are completely pleasant to drive with, glare-free even in snow or rain, unlike the Peugeot headlights which tend to scatter a lot of light upwards. Unfortunately, they are hardly available anywhere at reasonable prices anymore, even though several manufacturers still have them in their range. If anyone knows a source for these All Weather bulbs that doesn't charge three times the price of "normal" bulbs, please let me know!
Translated on 07-08-2026, 22:21.
15-11-2007, 12:51 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
ulf wrote: | Bertil wrote: | | What type of front crossmember does the Ibiza have? Plastic or metal? | Oh dear, that's a good question... I've never removed the front bumper before. But the upper locking rail "crossbar" is definitely made of sheet metal.
The headlights are probably attached to the top paneling, right?
Quote: |
Another idea:
Nice idea, it might work. However, the question is what happens at higher temperatures. You might end up damaging the lamps due to insufficient cooling and overheating. This certainly wouldn't be a problem in winter. Aluminum sheet metal would probably be the least "harmful" option, as it can dissipate heat itself.
I once used duct tape to secure the upper inner headlight bracket to the fender mounting on a colleague's car. This also minimized lamp wear.
It's a real pain to do, and every time you have to change a light bulb, it becomes an ordeal (which it already is without that).
Translated on 07-08-2026, 22:26.
15-11-2007, 13:54 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Bertil wrote: | ulf wrote: | Bertil wrote: | | What kind of front crossmember does the Ibiza have? Plastic or metal? | Oh dear, that's a good question... I've never disassembled the front bumper before. But the upper "crossbar" of the door frame is definitely made of sheet metal.
| The headlights are probably fastened to the upper profile sheet metal, right? | Yes, but not only that... I just took another look from the back: the parts supporting the radiator are also profile sheets connected (welded) to the upper crossmember. Therefore, the 6K lamps are likely mounted entirely on bare sheet metal. The headlight housings themselves are made of plastic, and inside them is where the actual motor-driven reflector for low beam is mounted.
Quote: | | Nice idea, it might work. But the question is what happens at higher temperatures. You might end up damaging the lamps due to insufficient cooling and overheating. | Um... does that mean that the lamp reflector is an essential part of the lamp's cooling system, absorbing heat from the bulb-side mounting plate via conduction and then dissipating it to the surroundings?
Translated on 07-08-2026, 22:29.
Profile PM Garage |
15-11-2007, 14:02 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Hi.
My H7 bulbs are probably among the most frequently replaced ones in this forum.
Since I'm driving a car with TFL (Torque Vectoring Limited Slip Differential), the turn signal lights activate with *every* significant steering wheel rotation.
Still waiting (9 months, 21,000 km), and nothing has happened yet.
If that were the case, there would also be macros as cool as the ones Roger has  .
Translated on 07-08-2026, 22:31.
Profile PM Garage |
Hutfahrer Schrauber
15-11-2007, 15:35 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Incandescent bulbs are typically not very sensitive to the frequency of switching on and off, as they are cycle-resistant, unlike fluorescent tubes, xenon headlights, etc. Therefore, the H7 bulbs used for turning lights are likely to be very old, as they probably won't reach their calculated operating hours anytime soon, possibly not even in years.
Regarding lamp cooling: It doesn't really matter to these devices whether or how they are cooled. What is important is that they are hung in a way that minimizes vibration, and that the power supply does not have any voltage surges or spikes.
Despite the approximately 14 V board voltage, car lamps are manufactured for a nominal voltage of 12 V. Why not increase the design voltage of lamps to 14 volts, for example, to avoid lamp failures, especially in new cars that deliver relatively high voltages? Because the European standard ECE legally stipulates a design voltage of 13.2 volts for headlight bulbs and 13.5 volts for auxiliary lights.
A change to the design stress is only possible after a standard revision.
The demands placed on lamps by the automotive industry today are better met with designs that utilize lower operating voltages. (Source: www.osram.de)
Translated on 07-08-2026, 22:33.
15-11-2007, 15:44 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
ulf wrote: | ... Consequently, the 6K headlights are likely to be mounted with the metal housings exposed. The headlight casings themselves are made of plastic, and inside them is where the actual motor-driven reflector for low beam adjustment is mounted.
"So, like with the Skoda 1M. In my opinion, this is better than the early plastic parts. It's strange; I would have expected this design to use fewer bulbs. Or maybe the metal is so thin that it vibrates even more. Compare it directly with the Polo. Just shake it and you should be able to see."
Quote: | | Um... does that mean the lamp reflector is an essential part of the lamp's cooling system, so it absorbs heat from the bulb-side mounting plate via thermal conduction and then dissipates it to the surroundings? |
At the very least, the lamp reflector helps to dissipate excess heat from the entire headlight system. You should keep that in mind.
Wie viel das ist kann ich nicht sagen. Ob die Wärme direkt aus dem Lampenhalter oder aber per Strahlungswärme aus der Glühlampe selber an den Reflektor gerät, dürfte egal sein. BeidIt is possible.
With plastic reflectors, you might even get into trouble doing that; they could even break.
Well, apart from the RoHS regulations (lead content in new vehicles) and the weight increase (increased consumption), there's not much to object to about your "lead method"... :duck and away:
Translated on 07-08-2026, 22:36.
15-11-2007, 15:47 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Hutfahrer wrote: | The only important thing is that they are hung in a way that minimizes vibration, and that the power supply does not have any overvoltage or voltage spikes.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Because the European standard ECE legally mandates a design voltage of 13.2 volts for headlight bulbs and 13.5 volts for auxiliary lights.
The current demands on lamps from the automotive industry can be better met with designs that use relatively lower voltages. (Source: www.osram.de) |
That would make my idea of using an RF filter in the lamp circuit twice as beneficial:
1) Suppression of voltage spikes.
2) Deliberate reduction of the operating voltage, for example, by using the longitudinal resistance of an inductor (choke).
Translated on 07-08-2026, 22:39.
Profile PM Garage |
15-11-2007, 15:52 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
Hutfahrer wrote: | Incandescent light bulbs are usually not very sensitive to the frequency of switching on and off.
If it's not a halogen lamp, then that statement is correct. Unfortunately, the H7 bulb is a halogen lamp. Each time it's switched on, the "halogen effect" needs to be initiated. During this period, the halogen lamp experiences greater "wear."
Quote: | ...
Regarding lamp cooling: These devices are relatively indifferent to whether or how they are cooled.
Unfortunately, the manufacturers of halogen lamps themselves specify the operating hours at certain temperatures. Beyond those temperatures, the lifespan decreases significantly.
Since I meant the warming up of the entire headlight, not just the light bulb, with Ulf (and he understood me that way), this is more of a minor detail.
Translated on 07-08-2026, 22:42.
15-11-2007, 15:54 Subject: Reduce H7 Bulb Wear: Tips & Tricks |
ulf wrote: |
2) Targeted reduction of the operating voltage, for example, through the longitudinal resistance of an inductor. |
... and darker light  .
Otherwise, there's nothing that can compete with the blackbird.
Translated on 07-08-2026, 22:43.
