Golf 5 Key Programming: How-To Guide
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
On-Board Diagnostics (OBD)
View previous topic
View next topic
Author
Message
chriskross
27-03-2011, 21:10
Subject: Golf 5 Key Programming: How-To Guide
Quote
Hello!
Is it still possible to program keys using VCDS on a 2007 Golf 5, provided you have the necessary login credentials?
best regards, chris
A6 AFB
A6 BRE DPF
Translated on 30-09-2026, 4:14.
Profile
PM
2018 Volkswagen T6
27-03-2011, 21:22
Translating...
[Translating...]
http://wiki.ross-tech.com/wiki/index.php/Immobilizer
Dipl.-Ing. (FH) Rainer Kaufmann -
Original VCDS mit KPower, KDataScope und Dieselschrauber Support
Profile
PM
WWW
Garage
mullemaus
28-03-2011, 0:29
Quote
2007 marked the transition from simply pre-programmed TX2x transponders to those that are pre-programmed specifically for each vehicle.
If it's an originally ordered one, it will work with the known login.
Translated on 30-09-2026, 4:15.
chriskross
Quote
Okay, thanks.
A6 AFB
A6 BRE DPF
Profile
PM
New Topic
Reply
View previous topic
View next topic
Topic
Forum
Steering Angle Sensor: How to Recalibrate?
Train T90 / T 91 with VCDS
T5 Model 2014 Key Programming via VCDS
Passat 3c key programming
Pairing key VW Crafter
VW Polo 6N: Key Programming Guide
VAG-COM: Key Programming with Version 409
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.109s
