Power Steering Pump Whining Noise
vikinger
Post23-03-2003, 16:03    Subject: Power Steering Pump Whining Noise Quote
I'm starting to get really frustrated. My power steering pump is making a loud squealing noise. In other posts here, I've seen that this can be caused by air in the system. I've already jacked up the car and turned the steering wheel from lock to lock about 10 times. Then I started and stopped the engine several times until the oil level stabilized. But it's all been for nothing, the noise won't go away. Does anyone know of a trick that might help?
Translated on 25-09-2026, 6:44.
Andy
Post23-03-2003, 16:25    Subject: Timing Belt: Replacement, Cost & Types Quote
Is the serpentine belt of the power steering pump properly tensioned?
Best, Andy.
Translated on 25-09-2026, 6:45.
joergs
Post23-03-2003, 18:54    Subject: Power Steering Pump Whining Noise Quote
It's also possible that the serpentine belt driving the power steering pump is slipping on the surface of the pulleys due to normal wear and tear, which can cause similar noises.
Translated on 25-09-2026, 6:46.
vikinger
Post23-03-2003, 20:09    Subject: Power Steering Pump Whining Noise Quote
The belt is new, and the car has only 50,000 km on it, so I'm less likely to suspect wear and tear. The timing belt is automatically tensioned by an oil damper, and I believe the tension is okay.
Mc_Givertechnik
2010 Volkswagen T5
Post23-03-2003, 20:29    Subject: Power Steering Pump Whining Noise Quote
Hello!
Well, there can't be that many possibilities left. It could be that a bearing in the pump is failing, or, as I suspect, that the pressure relief valve, which is supposed to release excess pressure when fully engaged, is stuck open or sometimes opens, and the oil flowing through it is causing the noise. But as I said, that's just a guess.
Regards, Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 25-09-2026, 6:47.
vikinger
Post23-03-2003, 21:06    Subject: Power Steering Pump Whining Noise Quote
Okay... I'm going to replace the pump now. Let's see if that fixes the problem.
kfh
Post25-03-2003, 9:49    Subject: Power Steering Pump Whining Noise Quote
A few sprays of oil/grease from the spray can helped me!
Sounds like new again icon_wink.gif.
(It wasn't just the servo that was squeaking, but also the other pulleys.)
KFH
Translated on 25-09-2026, 6:48.
No new posts Serpentine belt squealing! Diesel Engine Technology
No new posts T6 TDI, squealing ribbed belt, TPI Diesel Engine Technology
No new posts BMR KRR tensioner squeaks Diesel Engine Technology
No new posts Kupplung quietscht Diesel Engine Technology
