Boost Pressure via OBD2
vmann
Karma: +0 / -1   Thank you, like it!
Post20-04-2011, 10:05    Subject: Boost Pressure via OBD2 Quote
I installed a Garmin EcoRoute HD adapter in my Golf 4 Variant TDI (with MKB or ASZ engine). This device allows engine data to be displayed on the Garmin navigation system. The adapter connects to the diagnostic interface and transmits the data to the navigation system via Bluetooth. It is also possible to use a smartphone if the Garmin Mechanic app is installed.
"All the gauges are working except for the intake manifold pressure. In my Vito CDI and my wife's A200 turbo, the intake manifold pressure reading has always matched the boost pressure (compared to a mechanical boost gauge)."
"However, in my TDI, I always see a value of 1.55 bar. This value doesn't change even when the engine speed increases. Is there a particular characteristic of TDI PD engines regarding this?"
MB Vito 2,2 CDI
VW Golf IV 1,9 TDI Variant
Translated on 29-09-2026, 18:23.
haithamina
Post20-04-2011, 12:02    Subject: Boost Pressure via OBD2 Quote
I'm not aware of any issues, and the data reading via the OBD interface works both with VCDS and with a digital real-time display, a Scangauge, which I have installed on the steering column (I hope it's okay to mention the company here; otherwise, please remove it).
haithamina
Translated on 29-09-2026, 18:25.
Karma: +1098 / -0   Thank you, like it!
Post20-04-2011, 12:44    Subject: Boost Pressure via OBD2 Quote
I also have the Scangauge (permanently installed in the 206), and there was even a review of it by me. icon_wink.gif So, why shouldn't it fit?!
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post20-04-2011, 17:58    Subject: Boost Pressure via OBD2 Quote
"The driver should update his navigation system, and please don't post such low-quality content here anymore."
reflexsilber met.
Translated on 29-09-2026, 18:26.
vmann
Post20-04-2011, 19:24    Subject: Boost Pressure via OBD2 Quote
Thank you for the tip.
It works in other vehicles.
MB Vito 2,2 CDI
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OBD2 Adapter: MFA via OBD2 Diesel Engine Technology
No new posts OBD2 adapter Diesel Engine Technology
No new posts OBD2 Diagnostic Adapters: Buy Now! On-Board Diagnostics (OBD)
No new posts OBD2 for TDCi On-Board Diagnostics (OBD)
