Is a VE 5/8-L358 conversion possible?
schlauchdruide
Post17-04-2011, 8:07    Subject: Is a VE 5/8-L358 conversion possible? Quote
Is it possible to adjust the fuel injection pump from a VW T4 2.4D with engine code AAB so that it always operates at 3000 RPM, regardless of the load?
The context is a 40kW emergency generator with an engine failure, and this engine could be installed in it. The original motor had a rotary pump with a regulator that had a fixed stop for adjusting the speed.
As far as I recall, the pump enters an unregulated range at around 2000 RPM of engine speed and would require constant readjustment. The motor must not exceed a speed of 3100 RPM due to the risk of overvoltage.
If anyone is familiar with these types of pumps, I would appreciate their help.
It's a rather unusual question, but maybe someone knows the answer.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku keine Umcodierung möglich, 01K-01F Automatikgetriebe Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel Pre-Pump: Upgrade Options & Compatibility Diesel Engine Technology
No new posts TDI Injector Upgrade: 150HP to 180HP Conversion Diesel Engine Technology
No new posts Is it possible to retrofit a VE-ESP system from a Golf 4 ... Diesel Engine Technology
No new posts Is it possible to perform a turbo replacement for a 1.9 d... Diesel Engine Technology
