Temperature Display: Check & Troubleshooting
VWGOLFIII
Post28-03-2003, 10:53    Subject: Temperature Display: Check & Troubleshooting Quote
Hello.
Is there a way to test the temperature gauge that's located in the dashboard to see if it's working properly?
For example, unplugging a connector and bridging it with a wire, which can cause the display to go into the red zone!
Or with a program?
Thank you, and best regards from Kiel, from Mark.
Translated on 19-09-2026, 3:38.
VWGOLFIII
Post29-03-2003, 21:35    Subject: Temperature Display: Check & Troubleshooting Quote
Hello.
Can anyone help me?
Best, Mark.
Translated on 19-09-2026, 3:39.
Post30-03-2003, 13:13    Subject: Temperature Display: Check & Troubleshooting Quote
Hi.
"As is, where is" or "Without warranty."
Connect various resistors (or a potentiometer) to the input terminal and observe the display.
240 Ohms ≈ 60°
100 Ohms ≈ 90°
47 Ohms ≈ 120°
The stepper motor displays have an IMO idiotic "centering function" at 90°C, meaning that between approximately 80 and 100° (real temperature), the pointer is stuck at 90 icon_evil.gif.
Translated on 19-09-2026, 3:40.
joergs
Post30-03-2003, 20:02    Subject: Temperature Display: Check & Troubleshooting Quote
@vwgolfIII
Buy a repair manual with the motto 'now I'll help myself,' and you'll find everything in it, from the resistance curve to checking the display device!
If I weren't so lazy, I would have typed it out, but on the other hand, you can also invest in a little bit of know-how sometimes! icon_smile.gif
Translated on 19-09-2026, 3:41.
tora
Post30-03-2003, 23:28    Subject: Temperature Display: Troubleshooting & Help Quote
Hello.
Or with a program?
Thank you, and best regards from Kiel from Mark.
with a VAG1552!
You need to compare the temperatures in the engine control unit (ECU) and the shift table.
They must be identical!
Translated on 19-09-2026, 3:42.
VWGOLFIII
Post31-03-2003, 8:47    Subject: Temperature Display: Check & Troubleshooting Quote
Hello.
Thank you for the tips.
@ tora
Where can I find the designation '1552' in VCDS, or where do I need to enter '1552'?
Thank you, and best regards, Mark.
Translated on 19-09-2026, 3:43.
DocSnydor
Post31-03-2003, 9:02    Subject: Temperature Display: Check & Troubleshooting Quote
icon_lol.gif Tora refers to the device as 'VAG 1552'. That's the name VW uses for the box. VAG-COM emulates this device. I think you should just take a look at the measuring blocks; there are often 'coolant temperature' readings there. Also, check the error database...
Translated on 19-09-2026, 3:44.
VWGOLFIII
Post31-03-2003, 12:28    Subject: Temperature Display: Check & Troubleshooting Quote
Hi.
Thank you, icon_lol.gif icon_lol.gif.
Best, Mark.
Translated on 19-09-2026, 3:45.
No new posts Prüfen des Hallgebers von Zündanlagen Troubleshooting & Guides
No new posts TDI 1.9L Injection Pump: Testing & Adjustment Troubleshooting & Guides
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel and temperature gauge; worse after repair :-( Transmission, Chassis, Body & Interior
No new posts Testing and Adjustment of the TDI 1.9L Distributor Inject... Diesel Engine Technology
No new posts Oil Temperature: How to Check & Fix Diesel Engine Technology
No new posts Leadership shortage and increased consumption of AFN, ple... Upload
