AUDI 80 ABK - Severe shaking/vibration at low RPM in all gears - FOUND
Post11-05-2011, 22:51    Subject: AUDI 80 ABK - Severe shaking/vibration at low RPM in all gears - FOUND Quote
...and the CO level is very high! It's a 1993 model (manufactured in October) with 132,000 km on the odometer.
The oxygen sensor was measured with a multimeter, and it's fluctuating nicely between 0.1 and 0.9 volts.
Air mass sensor cleaned, tested while slowly moving the valve; no interruptions observed.
Throttle valve position sensor measured, OK.
Is there a known recurring problem? For example, some newer models have a four-sided ignition coil that malfunctions. This Audi has the older ignition module.
Vacuum leak test with brake cleaner: OK.
Exhaust manifold to oxygen sensor: OK.
Cat not clogged.
Translated on 08-07-2026, 11:06.
olli
Karma: +46 / -0   Thank you, like it!
Post11-05-2011, 22:56    Subject: AUDI 80 ABK - Severe shaking/vibration at low RPM in all gears - FOUND Quote
It could be a temperature sensor. It's not uncommon at that age. You can simply simulate a warm engine by using a suitable resistor in the connector. Normally, the engine control unit (ECU) is also diagnostic-capable; unfortunately, in my case, it only works when the engine is not running...
Best regards from Berlin,
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 08-07-2026, 11:08.
Karma: +1344 / -0   Thank you, like it!
Post11-05-2011, 23:49    Subject: AUDI 80 ABK - Severe shaking/vibration at low RPM in all gears - FOUND Quote
I once had a similar issue with an even older Audi 80 model. It had rough idling, unstable performance, and poor emissions readings. The mechanics struggled to find the problem. I eventually cleaned the air flow sensor myself, checked and resealed the fuel injectors, etc. In the end, it turned out to be the temperature sensor.
Translated on 08-07-2026, 11:09.
Post12-05-2011, 0:02    Subject: AUDI 80 ABK - Severe shaking/vibration at low RPM in all gears - FOUND Quote
That such a simple temperature sensor can make so much of a difference icon_eek.gif icon_eek.gif.
I will check it!
Post12-05-2011, 23:31    Subject: AUDI 80 ABK - Severe shaking/vibration at low RPM in all gears - FOUND Quote
Heukera, the Audi is now running great icon_lol.gif. Finally, it's drivable again.
Exhaust fumes now smell like a properly functioning lambda control system!
The temperature sensor was working correctly. The problem was with the relay number 30, which is located under the steering column. It had a cold solder joint, just like in cases with AFN and 1Z relays, specifically number 109.
I noticed that all the voltages on the MSTG side fluctuate wildly during the motor-saw cycle, even though the voltage at the battery remains constant at 14.2V. So, I checked the supply voltage of the MSTG, and sure enough, it fluctuates between 5-14 volts. icon_eek.gif
Caused by relay number 30.
It's amazing that the good old, simple Digifant has stood the test of time so well!
Unfortunately, I don't have a 2+2 cable for the classic cars icon_confused.gif, so I can't perform a VCDS diagnosis.
Would that have made a difference for me?
Translated on 08-07-2026, 11:11.
Post13-05-2011, 23:37    Subject: AUDI 80 ABK - Severe shaking/vibration at low RPM in all gears - FOUND Quote
Translated on 08-07-2026, 11:12.
No new posts Golf 1J: Grinding Noises in All Gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts New Audi 80 1Z 1.9 TDI smokes heavily and misfires Diesel Engine Technology
No new posts Diesel Engine Misfire: Why It Happens & Fixes On-Board Diagnostics (OBD)
No new posts Merry Christmas to all Diesel Engine Technology
No new posts LLM from DC: A Problem Solver for All Walks of Life? Diesel Engine Technology
